Question about Whirlpool Refrigerators
Whirlpool ED25PW 25.2cu ft. my wife cleaned our fridge and the next morning we realized that all lights in fridge and freezer do not work. Also the ice dispenser does not work.
aborcass
  • 2651 Answers
SOURCE: Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Posted on Mar 01, 2008
SOURCE: Water & Ice do not dispense. Maytag ICE2o
Possibly the water valve (also known as a solenoid valve) on the back of of your refeer has gone ka-put. It is easy to find and spot. The water line from your source (out of the wall) goes to this valve. If it is not operating, you will get no water supply thru that line into your dispenser or your ice-maker unit. No water in means no water and no ice out. This is a pretty simple fix you can do yourself. The part is reasonably priced. Get the model number of your refrigerator off the door and contact your local distributor for your brand. Make sure you turn your water off at the wall, or house, before you start taking that plumbing line apart. Otherwise, get yourself a surfboard and lay in a good supply of paper towels. Take your time and unplug your unit from the wall to be on the safe side...
Posted on Mar 06, 2008
  • 1073 Answers
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Posted on Apr 12, 2008
  • 125 Answers
SOURCE: ice make lines. What is the white long(25 ft) in
It is the chilled water resevior, so that when you get water from the dispenser it is chilled and not room temp.
Posted on Apr 19, 2009
  • 10865 Answers
SOURCE: 25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Posted on Aug 16, 2009
Where can i find a wiring diagram for whirlpool control board w10135090?
Normally unit technical sheet is hidden for technician reference inside the front bottom kick plate or just under it. Please put it back after using it to the right place. Next guy working on your fridge need to refer that.
Sep 03, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Water under fridge sometimes ice
Defrost unit and work everything loose. Wipe off all water and let it sit over night. Plug in next morning and allow 24 hours for temps to be right.
Sep 09, 2017 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whilpool fridge beeping and motor not running
refrigerator no more cool after my wife cleaned inside, can hear the click sometimes from relayer attached with compressor, but never get start for cooling, what should I do?
Thank you!
Dec 24, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Whirlpool fridge with top freezer.
Almost certainly iced up. Fully defrost and start again. Make sure the condenser is clear and clean
May 15, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a whirlpool side by side fridge. This
On some models you have a mother board located on the back outer section of the refrigerator that can be faulty. There is a tech sheet located behind the kick plate or under the front of the ref bottom to refer to. If someone olays with the digital controls you may have to reprogram the mother board, which is explained in the tech sheet.
Jul 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Jun 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No power to control unit in fridge
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge side by side and freezer not cooling
The fridge is working again and I don't understand why. Thanks anyway all is good.
Jul 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
