Question about Onkyo TX-SR500 Receiver
No power AMPLIFIER PROTECTION HASBEEN ACTIVATED
  • 1 more comment
  • Otto14 Feb 18, 2009
    After pressing the Power switch, the display lights up and immediately goes dead. I have no speakers or components connected to the receiver.
    According to my manual, the Amplifier Protection Circuitry has been activated, and only remedy is to contact an Onkyo Svc Ctr. I requested assistance with the problem on the Onkyo website 3 days ago, but they have not yet contacted me.
    Can I fix the Amp Protection Circuitry myself?
  • Anonymous Mar 02, 2009
    turn on the power and the receiver shuts off a second later.the standby light flashes.manual said amplifier protection circuit activated contact onkyo service center.called 1 8002291687 pressed promp #3 then got hung up on without even talking to someone.
  • rporter556 Apr 13, 2009
    I have the same problem. There are no wires touching. It will do it with nothing hooked to it.
    Problem Solver:
  • 5 Answers
My receiver has a similar problem. So far I have found a pair of output transistors fried shorted E to B to C (Q6051 and Q6061) and the associated ceramic current limiting resistor array (R6101) failed open. These bad components will definitely be sensed by the protection circuitry as an overload condition. I ordered some replacement transistors from Mouser (2STC4467 and 2STA1694) and the resistor (RSS2WK-0.22 ) from Encompass.
https://www.encompassparts.com/
I will let you know if this corrects the problem once the parts are installed. I also got a service manual from www.user-manuals.com which helps a lot.
Posted on May 02, 2009
  • 151 Answers
Check your speaker cables are not touching at the back of your amp or speakers.
Posted on May 27, 2008
I have a sony TA V715T amplifier i have got power put have no sound can you help
If there is any problem in the output amplifier section then the output repays will not get activated and you will not get any audio. What you have to check is power up the device and listen is there is any click noise comes from the amplifier (relay switching noise). If its not there then the protection stage is not allowing the activation of the relay. If so you have fault power amp stage either left or right.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 02, 2016 | Sony Audio Players & Recorders
Jbl dcr600ii receiver powers on and after 2-3 seconds, powers off, automatically
Protection circuits are on most activated after about 3 seconds.
If there are no faults detected it will power up normally.
If you need to troubleshoot and feel you can ,
post so I can help you further.
Sep 04, 2012 | JBL Audio Players & Recorders
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
My home theater system is showing push power protector on the read out and nothing is happening.
Push power protect is an error message that shows unit got some problem in output amplifier section and protection circuit is activated to avoid further damage.
Local tv repair shop will help you to fix it as unit will take apart and soldering work is also involved to replace bad amplifier output chips.
Aug 25, 2010 | Sony DAVHDX265 System
LIGHTS UP THEN TURNES OFF STRIGHT AWAY
sounds like your internal protection is being activated. either your speakers are connected wrong, or you have the volume up to loud, or there is something wrong in the unit itself and it should be fixed by someone who knows electronics
Mar 17, 2010 | Peavey Pv 2600 Power Amplifier
Amp protection circuit has been activated
1-check your input cables from connected equipments(cd player or dvd p
layer or any other media source).
2-adjust your input signal level(from-10 db to 0 db).
3-amplifier power must be bigger than total power of all loudspeaker with 20%----(if total power of loudspeaker is 8 watt amplifier must be 10 watt.
Nov 28, 2009 | Onkyo TX-SR605 Receiver
Red protection light wont turn 2 green no matter what so the amp wont work
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Aug 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
sometimes the protection circuit will enable because of a bad speaker i would suggest taking the load off of it by removing the speaker wires and turning it back on. if it stays on take an ohm meter and check the speakers should be between 2-4 ohms load.
May 01, 2009 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
Power shuts off immediatly after power on
you may have to many electronics plugged up to one circuit in your house. try plugging the sound system into a different socket and that might help.
Oct 31, 2007 | Onkyo SKS-HT500 System
Onkyo TX-SR500 Receiver Logo
467 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
