Question about HP Computers & Internet
Computer will not power up, power button comes on but nothing happens
  • slinky24 May 27, 2008
    No, no fans no hard drive running, its a hp pavilion 526X
  • Jane Doe May 11, 2010
    Can you hear the fans moving? can you hear the hard drive working?
    Scholar:
  • 60 Answers
If you're power button lights up but nothing is 'spinning' on the inside, it sounds like a motherboard failure. I would give HP a call to see if this is still under warranty. Since the HP site says this model was introductioned in 2003, I doubt that it is. But it doesn't hurt to check. If not, you'll need to either replace the motherboard yourself, or pay someone to do it for you.
Contact info:
http://welcome.hp.com/country/us/en/contact_us.html
They should also be able to point you in the right direction for instructions on how to replace your motherboard if you need to do this yourself.
Hope this helps! : )
Posted on May 27, 2008
    Scholar:
  • 110 Answers
I had this problem with my HP Pavilion DV series laptop. It had to go back and be replaced. It was only 3 months old too. If yours is still under warranty, lodge a "laptop dead" ticket, they'll send UPS to your door and pay all the shipping costs.
If there's any important data on it, you should expect to pay around $70 to a computer shop like Best Buy or Future Shop to have that data recovered. Do that before you send it off, because if they do elect to replace it, the hard drive won't be the same.
I have a Gateway DX-4720-03 when I press the "ON" button it lights up briefly then goes out and computer will not boot. Fans do not come on. nothing happens. (If I press button again immediately nothing...
I would actually lean a little more towards the power supply being the problem. You can either have someone locally test it for you, or you can buy a power supply tester to check it out.
Aug 26, 2010 | Gateway DX4720-03 PC Desktop
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
The computer does not start
Make sure at the very least that the power cable is plugged into the wall (or a UPS) AND into the computer (and it is switched on).
Try power button, if nothing happens then...
Look inside the computer, make sure that you have wires running from the front part of the case (usually near the power button) to some pins on the motherboard...
If not then you need to figure out what wires are what and plug them onto the pins (use the motherboard manual to figure this out, or the internet; google your motherboard name + jumper settings)
Try power button again, if nothing then try another power supply.
Post back if you have any further problems.
May 08, 2009 | Intel Motherboard
Dell Inspiron 530 I turns on and nothing happens
1.) If when hitting the power button, ABSOLUTELY nothing happens, no fans come on, nothing- You need a new power supply most likely. I see this all the time in my shop. Here's the bad news- Dell likes to use their own special power supplies, so a normal one may not even fit in the case. If that is the case, then I'm sorry to say Dell likes to charge over $100 easily for a new one.
2.) Fans come on, lights come on, but no screen. This can mean any number of things. Bad VGA cable (or DVI), bad RAM, bad mobo, even a bad PCI card. time to start troubleshooting. Change what parts you can, remove any PCI cards that are not needed, remove one RAM card then the other, etc....
Apr 29, 2009 | Dell Inspiron 530 Desktop Computer
HP 774y Does not turn on
No ,by the way this problem comes due to RAM.
chek your RAM.
Apr 03, 2009 | HP Computers & Internet
I press the power botton and nothing happens
It's possible that the spring clip behind the power button is broken and won't allow the power button to fully make contact. That's a fairly inexpensive fix. Or, some of the cables/wires could be loose, but I'm thinking (from your description) that it may just be the spring clip.
Feb 16, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
Computers & Internet Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
