Question about ASUS P5S800-VM Motherboard
I've put it back together, but it won't start. The green led is lit I may hav mixed upm the power button wiring. Would this be the cause
  • 1 more comment
  • snookertable Oct 05, 2010
    Thank you for your anser to my question, I realyy appreciate your help. Unfortunately it din't work. I had another person put in a SATA Hard drive because I couldn't get IDE at the time. After a few weeks the hard drive blew blew and the DVD burner door malfunctioned, so I got a new IDE DVD burner, new SATA 500 gb hard drive, new sound card and new graphics card. I Took the main PCB out and was going to put a whole new system in, but my son needs a computer, so I put this back together and in doing so put the reset plug where the one of the panel lights go. This was because of wrong colour coding in either the schematic of box. I've now sorted that out, but even after trying your suggestion, it won't work. I took the PCB back out, just to check for loose screws under, but there were none. I Really thought your suggestion was going to work, but alas, no. Is there someting else I can try. Please let me know. I can only get to this computer once a day, so hence the delay in replying.
    Regards
    Mike Heron
  • snookertable Oct 06, 2010
    I tried this, but it didn't work. I really thought that would be the answer, but alas no. I really appreciate your help I thought it was fantastic. Could it be the motherboard ? The green light is on, but it won't start.
    I replied to you via email, I hope you are still with me. I have now got it working partially. I found a problem with one of the PCB screws, which I have now fixed. There still seems to be a problem. I removed all components to see if any of them caused a problem and found that it would start using the reset button. The scematic colour scheme is wrong. I got the start button working Ok. Now it seems to be workin OK. It goes to show you were right, that particular screw must somehow have grounded. Once again Thanks a lot
  • 4,281 Answers
First reconnect ATX power supply from smps to motherboard. Pull cmos cell from motherboard for 10 minutes then put it back into it's position it is round cell on motherboard. You can check power cable diagram on motherboard corner near those pins. Then check.Also make sure motherboard is not ground with cabinet cover. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 04, 2010
Timer has 4 wires Blue, Green White and Black but wall switch only has black and white. where do I connect all the wires?
You are replacing a single-pole switch that has two wires.
You posted under UPM timer.
But UPM timers have a red wire instead of a blue wire, so you have different brand.
Some GE programmable timers and some Leviton timers have a blue wire.
Here are instructions:
-Green wire goes to bare ground wire.
-Timer black wire goes to black wire
-Timer blue wire goes to white wire.
-Located in back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to these wires. This will power electronics inside the timer.
-If your box does not have white neutral wires described above, then connect timer white wire to bare ground wire along with timer green wire.
-Turn power ON, and push on-off button. If timer works, then it is wired correctly.
- If timer doesn't work, then reverse Timer blue and Timer black wires.
- If lights blink on-and-off, then you connected white wire incorrectly, review wiring shown above.
If your box does not have neutral wires or bare ground wire as described above, then buy Walmart.s Brinks 46-1022 or Intermatic ST01C or Intermatic EJ500 or Aube T1032. These timers do not need neutral or bare ground wire.
Dec 31, 2010 | UPM Programmable Wall Switch Timer
GE smart digital timer was installed according to instructions. Timer was set to turn lights on at 5:30, and the lights blink on and off but will not stay on. I tried reprogramming, but same result. ...
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Dec 11, 2010 | UPM Programmable Wall Switch Timer
I have two 110V lines (two wire) coming into a box. I have 2 loads out (two wire). 1 load is always on and one is on a switch. All four whites are wire-nutted together. How do I incorporate this timer...
If I understand this correctly, you a have a 120 volt supply cable consisting of a black and white insulated wire. You have two cables that go out of the box - each of those cables has a black and white insulated wires as well. One of those load cables is to remain on all the time, the other is to be controlled by this switch.
You didn't provide a model number for your switch - and there are several made. If yours is the ETW350, or similar; it has a BLUE load wire, a WHITE neutral wire, a BLACK supply wire and a GREEN ground wire.
Connections are as follows. UPM GREEN wire connects to ground (that should be the the other bare or green insulated wires in the box). The UPM BLACK will connect to the other BLACK "supply wire" that is currently connected to the other BLACK "always on" load wire. The UPM BLUE connects to the BLACK load wire that is to be switched on and off. Lastly, the UPM WHITE wire will connect to the other WHITE wires that are currently all connected together.
If yours is not this model - I have no way of knowing how to help you wire it with any reasonable certainty. If you are unsure of the the model or are unable to locate the model info or manual, please call a licensed electrician to perform this work for you. Be safe, be smart.
I hope this helps & good luck!
Nov 02, 2010 | UPM Programmable Wall Switch Timer
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
Canon ip4200 waste absorber is full
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
(Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
5)At the end of the service mode, press the Power button
Jan 10, 2009 | Office Equipment & Supplies
Will not power on. Has power LED lit.
It's a component, you'll have to take it apart again, and go one by one. It could also be a component connector, be sure to check all connectors for bad wires or corrosion.
Jul 11, 2008 | Toshiba Satellite A105 Notebook
Mirus Desktop Computer
green-white for front panel Power indicator LED , Blue-white for RESET Switch , Orange-white for POWER BUTTON , Red-white for HDD LED . The berg pin header on the motherboard will have these legend printed just beside the connector or due to lack of space slightly away from it .
Apr 15, 2008 | Computers & Internet
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
ASUS P5S800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
