Question about Seagate (ST380011A) 80 GB IDE Hard Drive
Mayday! Mayday!! Have an 80gig hdd. Had 3 partitions on it. Now one of them is not accessible. says drive corrupt or inaccessable. i think a virus of some kind messed it up. all my data is on that drive n i cannot access.... pls help!!
  • 45 Answers
If you are using windows explorer then i'd say you're pooched on getting the info out.
you could always attempt loading up DOS and finding the drive that has been lost. from there you can copy the info from that drive to one of the other partitions. if this doesn't work then the only other thing i could suggest would be to get a pro, or use an external back up drive with the "one touch back-up" functionality and see if that works.
but try DOS first.
Posted on May 27, 2008
My computer doesn't recognize my fantom drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files.
Jun 01, 2012 | Fantom Drives 120 GB Hard Drive
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Error message that says Drive is not accessible. The file or directory is corrupted and unreadable.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
Hard disk prolem'
Probablel corrupt partition. Please advise which OS you are using. In windows you can access the drive from disk managerment from where you can re-partition and format it. Keep me posted
Jul 26, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
HDD replacement
Depending on the age of the device and the drive architecture, there should be no limits. Go as large as your budget allows. Remember, only certain operating systems can utilize drives bigger than 137 GB (Windows XP SP and higher, Windows Vista) without splitting into multiple partitions.
Apr 01, 2009 | Computers & Internet
NEC versa E2000 N/B reformat or repair install
f,11 will bring up system restore,and its self giuding from thier good luck.spucky.
Oct 26, 2008 | NEC Versa SX Notebook
Hard Drive Partition Table Error
If you have a spare HDD, you could install win xP onto that and set the problem drive as a slave. You may then be able to access the slave drive and save some of your files.
Apr 27, 2008 | Seagate Barracuda 7200.8 300 GB Hard Drive
My Samsung HDD SP0802N 80 GB PATA says read error and not booting
dear suresh
just trying using hdd utility like partition magic or with disk management in window
but i supposed to fixed it in another pc , you can partition it with two or three partition
after that youcan format it
Mar 18, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
for you able to combine again. you can use the software named partition magic.
Oct 13, 2007 | Bose Companion 3 Computer Speakers
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
24 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
