Question about HP Compaq d530 SFF PC Desktop
I have recently replace motherboard of hp compaq d530 with dc5000, after replacing an error is displays while starts system with single beep (920-fan command 2 pin connector from power supply not connected)
5 Suggested Answers
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
Posted on Feb 22, 2010
  • 10 Answers
SOURCE: 920-fan command 2 pin connector not connected
put a standard mother board jumper on it
Posted on Jan 31, 2011
  • 357 Answers
SOURCE: hp disktop erreur 920-fan command
The CPU Fan is not working. Contact Compaq or go on Ebay and see if you can find a replacement fan. If you continue using your PC without the CPU fan operating, you will burn out the CPU. I hope this helps. Good luck and have a pleasent day.
Posted on Apr 30, 2011
HP d530 920 & 162 Error And Parity Check 2 Hold On
Try installing the original RAM and see if the computer boots up.
If it does then the other RAM modules maybe incompatible or faulty.
Try using additional or new of the same make and speed as your original RAM.
Apr 16, 2013 | HP Compaq d530 SFF PC Desktop
Hp disktop erreur 920-fan command 2 pin connector
Apr 30, 2011 | HP Compaq d530 SFF PC Desktop
Hp compaq d530 motherboard is not responding,what do i do?
hi, try replacing the battery of the motherboard for it may be worn, a faulty battery usually makes the board not to work or sluggish. hope this helps
Feb 19, 2010 | HP Compaq Motherboard
Where are the SATA ports on the hp compaq dc5000 sff mother board?
To the best of my knowledge and working with HP/Compaq for over 8 years, this model does not have SATA ports on the motherboard unless someone has customized your system with a new board other than that which came as the original board.
C2Solutions
Jan 09, 2010 | HP Compaq Business d530 Small Form Factor...
Sep 22, 2009 | HP Compaq Business Desktop d330 Slim Tower
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
5 beeps HP Compaq d530
5 Beeps
CPU or motherboard problem
Apr 11, 2008 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq dc5000
Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Feb 06, 2008 | HP Compaq dc5100 PC Desktop
HP D530 Will not start:
It can't be the RAM, it would be beeping if the RAM was not installed properly. If it was and they were bad, it would fail in Windows.
We've had numerous similar problems to yours with our D530's. Check the motherboard to see if any of the capacitors (round barrel shaped components) are swollen (round on top) or leaking. It is a known manufacturers defect and they were replacing those motherboards for free, unfortunately that program just ended.
If the capacitors are all flat on top, its probably the power supply. We've had four go bad in the past month. They sometimes smell like something is burning before they go bad. The D-530 model is unfortunately our most unreliable model ever, they are junk. Good luck.
Nov 26, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq d530 SFF PC Desktop Logo
287 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
