Question about Amana NAV8800E Top Load Washer
Smoke I started the washer and about 1 minute later it stopped, so I checked and it was smoking from both the control panel and tub! I let it sit for a bit, then was able to run the spin & rinse cycles. The smoke smelled like electrical, not rubber. Any Ideas??
  • abcds May 27, 2008
    A correction... the model is Amana NAV8800AWW not the E if that matters. Also the tub was filled all the way... it stopped working about one minute after the agitation started. I will check the water inlet connection area.
  • 525 Answers
Your complaint is a bit vague but since it had only been in the cycle for 1 min., it should have been too soon to have enough water to start washing, so it's possible that the fill valve may have shorted out. Unplug the washer and inspect the area where your hot and cold fill hoses connect to the washer. Turn the water off and remove the hoses. If you can gain access to the part that the hoses were connected to, you should be able to visualize where the burning came from. It is possible a small water leak may have dripped onto the coils of the valve and caused it to short out, so that will need to be fixed also.
Hopefully, This is what your problem is.
Posted on May 27, 2008
  • David Emmel
    David Emmel May 29, 2008
    Ok, your clarification leads me to to suspecct that you may have overloaded the washer and this would cause the belt to burn and the motor to overheat and shut down. Inspect your drive belt to see how severely it was damaged. Your motor should not have been harmed.
My 95 Integra smoke at the start white smoke what is that five minutes later it goes away
White Smoke --usually a sign of a failed head gasket
or other issue, allowing coolant into the cylinder & a major
repair
White Smoke only on start up after sitting (Not Lasting 5 Min)
is raw fuel (gasoline) from leaking injectors, leaking fuel into
the cylinders
Injectors can fail,wear,leak or be dirty & NO you can not clean them
Forget the Genie in a Bottle The injectors have to come out & be
mailed away for Ultra-Sonic Cleaning
That condition - the raw fuel- will over heat your exhaust converter
& ruin it as well as many other problems-lack of fuel control the
main one.
Jul 19, 2014 | 1995 Acura Integra Coupe
I have a Kenmore Oasis Elite 110.280442700. I bought it at the beggining of 2008, never has given me any problem. About a month ago, it started to make a really loud noise during a spinning cycle, as if it...
April, You say you are suspicious that the smoke could have originated from the motor, BUT have you confirmed it? Have you tried running a short cycle without a load to see if the spin cycle rattles the machine or whether the machine works? Watch for smoke and turn off the machine immediately if you see or smell burning. If the motor is burnt, I think replacing should not be an option but rather replacing the machine should be considered.
Mar 01, 2014 | Kenmore 22642 Top Load Washer
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Sears pressure washer
sounds like the engine is over heating have you checked the oil?remove the top cover from the engine and look for a mouse nest
Jul 27, 2012 | Craftsman 3000 PSI 28 GPM Honda Powered...
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Amana NAV8800E Top Load Washer Logo
195 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
