Question about Acer Aspire 5610-4648 Notebook
Sound device not install . cleaned out computer and now no sound
  • Lee N.
    Lee N. May 11, 2010
    need more info than that
  • 426 Answers
Just clearing out my work que
Posted on Jun 19, 2008
No Sound, Sound device not showing up on HP a1240n motherboard D33005
you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
cleaning your computer of dust using a fine air blower from a compressor making VERY sure that
there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD you might even remove the sound card to clean the socket dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jul 24, 2012 | HP Pavilion a1240n (EG136AA) PC Desktop
No audio device in my computer, how can i check if my sound card have defect?
If the computer prompt you that you have no audio device, then your soundcard really is defective or has a dirty contact point of which your computer cannot detect. Clean the contact points first, then plug it again on your computers internal PCI slot that is located on your motherboards surface. If your computer still cannot detect a new device installed, then your sound card is definitely defective and needs to be replaced. But if your computer has detected a new hardware device installed but prompt you to install a driver, then your sound card is working properly and just need the proper driver for it to work properly. Just install the sound card driver from the mini disk that you have. When you buy a sound card a mini disk always goes along with it. Hope this would help you. Have a nice day my friend.
Aug 17, 2011 | Computers & Internet
The operation system in my computer is Windows xp professional service pack3. I have intel D101GGC motherboard. I installed the audio driver AUD_XP_5.10.0.6201_PV.exe to my computer but it was not...
you might not have a sound card installed on your computer or it might not be recognised due to a dirty socket if there is a sound card you could remove it from the socket and clean it if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
you might have to get another sound card or a portable usb sound card if you dont have a sound card installed
hope this helps
Apr 13, 2011 | Intel D101GGC Motherboard
I purchased d845grg but when i install sound driver it give error "NO SOUND DEVICE "please tell me which driver should i install
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
you might have to get a portable usb sound card if you mean dont have a sound card installed
hope this helps
don
Feb 21, 2011 | Computers & Internet
Cleaned computer files. Speakers' light is on. No sound accept a short scratch sound when light green cable is plugged in or being disconnected.
also
hope this helps
don
Feb 19, 2011 | Logitech R-10 Computer Speakers
No audio output device is installed
Not knowing what type of motherboard you have, it could be one of the following:
1. No audio chipset installed
2. No drivers were loaded
3. drivers are corrupted
If running Windows XP go under "Control Panel","System","Hardware","Device Manager" and
check under Sound ( click on + ) to see what is installed..
Feb 06, 2011 | Computers & Internet
There is a yellow question mark on SM bus controller, video controller, audio device as shown on device manager after i have clean install Windows XP pro in my desktop pc. and no sound coming from the...
You will need to go to the compaq site and download the drivers for your machine. You will have a tag number on the computer , enter that and it will take you to your machine to download the drivers you need
Jan 02, 2010 | Compaq Computers & Internet
Sound problem
You need to install the drivers for your sound card as when you format a drive you wipe it clean.
Identify your sound card, and download from there site.
May 15, 2009 | Computers & Internet
My computer says i have no sound device installed
Press windows key and pause/break button.
System propertise comes up - go to hardware
device manager
sound card
uninstall reinstall
if it dont automatically find the driver and install it download device identifier
at
http://www.zhangduo.com/udi.html
find it right click find driver
install goodluck
Dec 02, 2008 | Audio Players & Recorders
Sound device
If your sound device is removable, like PCI Card, try to remove the PCI Card and clean the connector with dry brush, then place it firmly back again.
If your sound device built-in on your motherboard, please re-install the Device driver provided by the Motherbard Driver CD.
-mrsolution
Jun 11, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
