Question about HP DeskJet 3745 Printer
Paper is not loading
My Printer is not taking in the paper when i click print. I reloaded the printer but same problem. I check the cable same problem. I check inside to see if any thing is blocking it but notthing i need some help.
    Problem Solver:
  • 13 Answers
What's the brand of your printer?if its hp, then it takes several minutes before the paper would feed. it still wont work try to restart your printer
Posted on May 27, 2008
Error, paper out, when paper is loaded.
check there is the sensor cable is broken or the sensor is faulty.
Oct 12, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Receipt printer paper reduction isn't working
Power the printer on and press the Paper button to see if paper will load.
If the paper doesn't load, make sure the paper isn't curled or creased, isn't loaded above the arrow on the left edge guide, and that the paper isn't jammed in the printer.
Take the paper stack from the tray; fan it before attempting to print.
Make sure the paper stack is leaning against the paper tray and not standing straight up in the tray.
If the Paper Out light is on solid, reload the paper, making sure the paper edge guide is adjusted to fit the paper's width, and then press the Paper button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload the paper, turn the printer back on, and try pressing the Paper Feed button again to see if the printer will now successfully load the paper. If the problem persists, power the printer off, remove the printer cable, and make sure all of the packing materials are removed.
If the problem is not resolved, contact Epson's technical support for further assistance.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Dec 10, 2012 | Epson TM-T88V (Part C31CA85081) Power...
Unable to print on network it is showing offline or load letter. How to resolve?
I can help you with your HP Laserjet 4 printer problem.
Ensure the paper is loading correctly from the paper tray by reloading paper and printing locally.
If the printer prints locally, then paper loading is not the problem. Select your printer from the Control Panel > Printers list, right click and choose Sharing to re-setup printer sharing.
I hope that helps.
Aug 30, 2010 | HP LaserJet 4 plus Printer
My lexmark all in one printer x5470 keeps jamming the paper and it wont print?or the paper will go in partially and print but nothing will happen then it will tell me to reload the paper and press the...
Most probably a mechanism problem. Try to remove all sheets of paper. Take out the cartridges from the printer. Close the cover. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Check for any obstructions or foreign objects in the feeder. Wait at least 30 seconds before plugging the power supply back in the printer. Once printer is ready, reload the cartridges. Load about 10-15 sheets, don't load too much. Let it print the alignment page. If this doesn't help, then most probably it's a hardware issue. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
Jun 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
press the Load/Eject button again to see if the paper will now load.
the paper, turn the printer back on, and try pressing Load/Eject
If the printer still will not load paper, power the printer off,
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
LED BLINKING
Replace the communication cable (parallel cable).
Dec 11, 2007 | Epson FX 1170 Matrix Printer
Problem with Brother MFC-9420CN
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Nov 07, 2007 | Office Equipment & Supplies
HP DeskJet 3745 Printer Logo
52 people viewed this question
Ben Johnson
