Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a coil problem that keeps burning out. How many times do I keep replacing it if it's another problem? It runs for about half hour and then shuts off. I'm thinking it can't be fixed and I may as well buy another lawn tractor
4 Suggested Answers
wadembly
  • 448 Answers
SOURCE: john deere 285 lawn tractor only firing on one cylinder
check compression in that cylinder the other thing it could be is the gap between the magneto & flywheel & also check to make sure there is no rust on flywheel
Posted on Jul 08, 2009
  • 640 Answers
SOURCE: my husqvarna 2754gls lawn tractor keeps blowing
Most likely you have a short circuit somewhere. You will need to inspect your electrical system. This is easier to do with a digital multimeter (DMM), because you can lift a lead and check resistance. Without a meter, you are going to have to look by hand over one inch of electical wire at a time, checking anywhere that it can rub against an edge. You could go to sears or somewhere and pick up an affordable one for fifteen to twenty bucks.
Posted on Sep 20, 2011
  • 27 Answers
SOURCE: My Husqvarna lawn tractor started smoking terrible
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
Posted on May 08, 2009
Tip
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
on Dec 24, 2010 | Refrigerators
Spark plug keeps burning out
getting it wet w/ anything makes the sparkplug busted,or its not compatible w/ the cdi .
Apr 03, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
My westinghous side by side fridge keeps on tripping after every 3 hours .
Probably the result of the compressor being overworked, either because of an accumulation of dust and dirt on the bottom coils or a burned out fan. Both are relatively easy to fix yourself.
I preach the gospel of keeping your refrigerator clean. Accumulation of dirt and dust on the bottom coils can make your compressor build up enormous amounts of pressure in the line and make it VERY difficult to start and run. Clean the coils and while you've go the back off the refrigerator, make sure the fan is running when the refrigerator is running. If not, replace the fan.
Odds are that one of these two simple fixes (which you can do yourself) will fix the problem. If not, you'll probably have to call a repairman.
Mar 17, 2013 | Refrigerators
I keep burning up starters
time to swap that old engine for a rebuilt one. that way you do not have to run the starter for half hour before it starts.
Aug 29, 2011 | 1988 Ford F 150
I have a 84 camaro with hei distributor motor is a 69 camaro 350 i keep melting the wires on the coil put new coil in car runs good for an hour or so then gets warm and melts wires and stall also did new...
HEI distributor and burning coils,it in you connection first make sure you install primary and secondary prorperly as it comes out of the cap , and inside the cap wire from modules dont make contact if you are burning its from primary circuit, this is the (B+) or (battery most likely), your secondary is your tach and that need to switch from postitive to negative for it to create spark obvously if tach was grounded or applied power you wont start,but there are times the condensor in the distributor does stays fixed and shorts out the coil (replace that condensor its for suppression) when the condensor is replaced run a fused direct wire at B+ (from ignition) run the vehicle and monitor the tach wire and check to see if that get hot
May 08, 2011 | 1984 Chevrolet Camaro
I have a 1982 Chevy k 10 and the ignition coil keeps buring out. I have replaced it several times and it starts fine after replacement but then burns up within 15 minutes of running time and then the car...
Check your charging voltage. It should not be any higher than 14v (even that is high if it does not drop) If it's high, check the regulator in the alternator and make sure you have a good ground to the engine and even if necessary to the alternator itself.
If the coil is still giving you problems after correcting any alternator problems you can add a chrysler type ballast resistor to the power line to the coil. That should lower the voltage enough to keep it from burning out.
Jan 18, 2010 | 1994 Chevrolet S-10
1984 K10 burns up coil..replaced several times won't start..was running
might need new spark plugs or wires. sounds like the coil is working too hard to keep it running.
Dec 30, 2009 | 1984 Chevrolet Chevy
Burns out foul pumps
thanks for getting back well about an hour an i have put 5 of them in an they run great for that hour cleaned tank an sending unit an all liens o an you no its a 7.3 liter deisel
Aug 30, 2008 | 1999 Ford F350 Regular Cab
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
81 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
