Question about Haier HBCN05FVS Wine Cooler
The coldest I can get a beverage to cool is about 55 degrees F. This is marketed as a beverage cooler, not just a wine cooler. Should this be able to cool a beverage a colder temp than this, to about 35 degrees.
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
SOURCE: Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Posted on Sep 03, 2008
ramon49
  • 111 Answers
SOURCE: my wine cooler does not cool
the fuse is one problem. The other is the fan motor is dead. If you can check voltage you'll find 2-7 volts at the CN red plug on the circuit board. Or power up the fan with batteries. If fan doesn't spin then you have the solution...Safety first unplug...
Posted on Mar 07, 2009
SOURCE: THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Posted on Apr 30, 2010
Edgestar cwr300sz
This cooler's operating range is 40-65 F. If it is still in warranty contact the manufacturer. You could have a faulty thermostat. If so have it replaced.
Dec 30, 2013 | EdgeStar BWC120SS (36 cu ft) Wine Cooler...
My wine cooler won't go below 12degree
wine should not be colder than 45 degrees, it mutes the flavor..If you wanted something to go lower you should have gotten a beverage cooler, not a wine cooler :)
Dec 09, 2013 | CDA FWC150 Compact Wine Cooler
Wine cooler not cool
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Does not chill drinks
you wrote that the wine cooler "only cools to 12 degrees minimum" I don't understand the problem?
12 degrees is really cold, in fact its freezing.
Oct 29, 2008 | Sunpentown Platinum Trim Cabinet...
Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Haier HBCN05FVS Wine Cooler Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
