Question about HP PSC 2210 All-In-One InkJet Printer
Photo card inserted backwards error
I tried to insert a compact flash photo card in my 2210 but got an error that it was in backwards and to reinsert with back label facing right. I have removed the photo card and unplugged the printer , tried rebooting it and still have the same error and red light next to photo card blinking red-unable to print or do anything else from printer-what do I need to do so I can use my printer again????
  • Anonymous Jul 22, 2008
    I have the same problem card is in backwards error and red light on even when their isnt a card inserted
  • Anonymous Apr 20, 2009
    THIS WORKED FOR ME, THANKS!
  • 234 Answers
Try a full NVM reset on the unit and check
Reset Steps are.
Unplug the power cord from the unit when there is still power in the All-In-One and press and hold the # and No 9 Button without releasing the buttons plugg the power cable back, it should come up with a message as reset
If the screen go's blank after you connect power cable, then release the keys and turn the power On, it will come up with a message as Full NVM Reset
Good Luck
Posted on Aug 29, 2008
Where do i insert my compact flash
You need to insert your compact flash memory card into an USB CF card reader then plug the card reader into the USB port of your computer. Your computer will detect it as an external storage device then you can open the image folder and copy the photos to your computer.
Mar 28, 2012 | Acer Aspire 1691WLMi Notebook
Photo card in backwards message but no card in machine
I am not real familiar with these things, I am More familiar with large copiers and Printers.
But i will give it a shot anyway?
Here is my suggestion..
All of these machines have Senors in then, which can send a false signal.
Take the ink Cartridge out and get a lint free cloth and a big can of air.
Turn it on it side and spray it out with that can of air. Wipe any dust / dirt you might see. (be careful and gentle)
Espically clean any metal contacts that you might see as well.
and a flash light might help to see..
Good Luck
Oct 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
Internal memory??
Highly recommend that you consider using a card reader to download you pictures. You insert the camera's memory card into the reader, and then insert the reader into a USB port on your computer. The card then shows up as a hard drive so that you can simply copy/paste or drag your picture files onto your computer. Card readers are much more faster in downloading pics, do not require the use of your camera's batteries, and provide much more reliable downloading of the pictures (fewer errors). They're also VERY inexpensive these days. Here are some examples of CF card readers from Amazon:
http://www.amazon.com/s/qid=1223745821/ref=sr_st?keywords=cf+compact+flash+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acf+compact+flash+card+reader&sort=price
Also, if the card has somehow become corrupted, take no more pics until you've recovered the photos. Take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will also need to use a card reader with this software. Finally AFTER you've recovered your photos, recommend formatting the card IN YOUR CAMERA to prevent this from happening again. Note that formatting will totally erase your card. Turn on the camera, press the menu button, select the tools menu. Go down to the selection that states your CF card's memory capacity and select it. Then follow the formatting prompts.
Oct 08, 2008 | Canon PowerShot A75 Digital Camera
Downloading photos from my Canon A95
Sounds like the card has become corrupted. Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
You will need to use a flash card reader with this software. Also, highly recommend that you consider using a card reader to download your pictures in the future. You insert the camera's memory card into the reader, and then insert the reader into a USB port on your computer. The card then shows up as a hard drive so that you can simply copy/paste or drag your picture files onto your computer. Card readers are much more faster in downloading pics, do not require the use of your camera's batteries, and provide much more reliable downloading of the pictures (fewer errors). They're also VERY inexpensive these days. Here are some examples from Amazon for your CF card:
And finally, recommend formatting your card in your camera only AFTER you've recovered your photos (this will erase the card). This should fix the card for future use. Turn on the camera, select menu, then select the tools menu. Scroll down to the selection outlining your's cards memory capacity and select it. Then follow the formatting prompts.
Oct 06, 2008 | Canon PowerShot A95 Digital Camera
Camera locked up error code (compact flash error)
Remove the card and look in the slot for a bent pin. If you see one, remove the batteries also. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Sep 04, 2008 | Canon Cameras
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Copying photos
Try inserting the card to another reader (laptop or another PC).
May 27, 2008 | Brother MultiFunction Center MFC-440CN...
Memory card error
did you try pluging the card into the pc using a card reader
May 01, 2008 | Archos AV400 Digital Media Player
Memory card issue with Epson r300
Hi , reinstall the printer driver with sd inserted.
Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
HP PSC 2210 All-In-One InkJet Printer Logo
276 people viewed this question
Ben Johnson
