Question about Sennheiser HDR 120 Consumer Headphones
Audio cuts out after three miunutes - Sennheiser HDR 120 Consumer Headphones
Yes turn up the volume on your device, then turn it down on your headphones. problem solved
Posted on Jan 15, 2013
I have no solution but the same problem.
the tr120 worked properly with a GRUNDIG-TV-unit.
After replacing the TV-unit with a SAMSUNG, the problem occurs.
I take the audio-signal out of the scart-connector (the unit has an earphone-connector but cuts of the internal speaker - this is not wanted in our usage).
might be an impedance-problem? or the scart-audio-output is too low for the headset-transmitter?
any further ideas and hints to get rid of the problem?
Posted on Dec 03, 2010
  • kartmann_109 Mar 14, 2011
    I have had the same problem with my HDR120s and Panasonic LCD TV but I think it is due to the tv volume level being too low for the headphone base unit to sense a signal so it cuts out after 3 mins.
Yamaha rxv1600 speakers keep cutting in and out when i turn the volume loud
The most likely cause is the audio output semiconductors gets to hot, or bad solder connections, but if you run the volume at half to three quarters the amp will start to clip drawing more power from amplifier the outputs will go into thermal runner way causing a shutdown.
Mar 14, 2012 | Yamaha Audio Players & Recorders
Tip
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut...
Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below:
Part One: Convert flip to Final Cut Pro video
Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro.
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter.
Step 2: Select a Final Cut Pro supported output format
Click the Profile drop-up list and select
Step3: Convert flip video to Final Cut Pro
Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro.
Part Two: Import converted videos to Final Cut Pro
Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file.
Step 2: Find the file in the resources list for the project.
Step 3: Drag the file into the Timeline and then save the project.
Part Three: Edit flip video in Final Cut Pro
Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline:
Step1: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Step2: Add transitions
For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Step3: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there.
You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro.
If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
on Aug 13, 2010 | Computers & Internet
Car overheats after driving for a few miunutes check guages light comes on
have you changed your transmission oil at all? or what about regular oil for that matter? if no to either of these try that
May 02, 2011 | 2001 Jeep Grand Cherokee
Running four S70 Siroccos off the amp, everytime volume gets halfway the protection is cutting in with protection light flashing three times? When reducing down to two speakers amp cuts out three quarters...
You are overloading your amp. IMO 640A cannot handle heavy loads.
Better change the speaker combo and connect something that puts right load on the 640A. Else, get a meaty amp from CA.
Mar 04, 2011 | Cambridge Audio Azur 640A Amplifier
Digital cable audio connection issues?
Digital is much more sensitive to "noise" and cuts out if signal is not strong. Contact your cable company to have them check the signal level you are receiving.
Jul 17, 2009 | Samsung LN46A650 46 in. LCD HDTV
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Is the audio technica at2020 a sealed unit
No it's not a sealed mic... there are three Philips head screws under the label ring just below the pop screen. You can either peel up the ring and loose the Audio Technica logo and markings or, as I did, simply use a razor blade to cut out around the screw holes.
After opening your mic you can GENTLY peel the foam from the condenser film to boost performance and response but only if you have a very good pop filter.
Justin
Nov 22, 2008 | Audio Players & Recorders
Mp2035 cd player will not turn on.
My hunch is that the fuses blew. When you cut all three at once you shorted the battery to ground and most likely blew out the fuses. Check the fuses and let me know. That is my best guess. Good luck
-Andrew Hawkins
Jun 10, 2008 | Kenwood KDC-MP2035 CD Player
Sennheiser HDR 120 Consumer Headphones Logo
744 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
