Question about Panasonic KX-T7630 Corded Phone
I need a operating manual to do time setting etc
  • Panasonic Master
  • 2,460 Answers
I have installed a new adjustable thermostat unit (E1-BCANRT1W). Temp is set at 91 deg and I am using the timer. Two time periods are set and the switch is set to timer (not ON). The unit comes on at...
Double check your slide switch.
For timer: set switch to TIMER
For thermostat: set switch to ON
If slide switch does not operate, then Autocirc may be defective
Laing (800) 554-6853
http://waterheatertimer.org/pdf/Laing-E1-E3-E10-install-instructions.pdf
http://waterheatertimer.org/pdf/Auto-circ-manual.pdf
http://waterheatertimer.org/Water-heater-recirculation-system.html
1) Household AC wiring will not affect the timer.
You can check your outlet using cheap circuit analyzer from home center.
The clock rotates one direction and the pins push small lever down which turns motor on-off.
When the OFF pins pass, the small lever snaps back and the motor turns ON.
I cannot immediately find operation manual for the E-1 model.
Typical ACT303 auto circ manual says following:
2) If timer controlled operation is desired, set timer and move slide switch to TIMER:
Manual says: tabs/pins are outward for ON times.
Another sentence says UPWARD, so I don't know which way the pins are set for sure.
So if you want timer ON for 2 hours, you would set 4 consecutive pins outward or upward.
ON for 6 hours, set 12 consecutive pins outward or upward.
If the timer turns ON in reverse of instructions, then set the pins that way.
Autocirc does not make the timer, they buy timer modules from clock-makers like Grasslin, Intermatic, etc.
3) To operate Autocir thermostatically without the timer, slide switch to ON position.
The clock dial will continue rotating
Apr 14, 2011 | Laing Thermotech Autocirc Undersink...
My daughter has just moved house and inherited a Randall 702 time unit for her central heating but no manual was left. Where can she download one for free, please?
This programmer is very easy to use, I wish I could get a modern one so simple.
Use the 6 white buttons along the top to move the time setting bars to the desirded on/off times.
Then using the two rows of switches below decide if you want hot water or heating between the time bars.
Switch 1 is for operation between bars 1 & 2
Switch 2 is for operation between bars 2 & 3
etc
but Switch 6 is for operation between time 6 and time 1 the next day.
The slider switch has 3 positions
Off, Auto (ie the time settings above), and On all the time
Hope this helps but if you are scrapping the programmer please let me know
Dec 18, 2010 | Heating & Cooling
Canon IXUS M-1 SET Compact Camera instructions need instruction booklet to operate time/ date etc...
Hello
OK, you will be able to download the manual at the link below.
Click HERE.
Let me know if you found this helpful.
Kind regards
Andrea
Sep 08, 2010 | Canon IXUS V2 Digital Camera
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Logitech MX3200 I need the operating instruction. How to set time etc. It arrived with Chinese letters.
Found manual here: http://safemanuals.com/user-guide-instructions-owner-manual/LOGITECH/CORDLESS%20DESKTOP%20MX3200%20LASER-_E
Click the PDF link that says download complete guide here.
You may have to answer a brief survey. But the download is free and you do not have to register for it.
Oct 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
Need the manual to understand operation, problems with drying
84052/94052 is the stock number and 417.94052500 is the actual model number
How long did you let it run on sensor? Some models may need to sense for a while before they decide to start heating.
The knob can be turned either way
Manual: http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502104.pdf
Sep 02, 2009 | Kenmore Dryers
Need owner's manual to set time
i can't set the time i need help
Apr 12, 2008 | RCA RP4803 Clock Radio
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Panasonic KX-T7630 Corded Phone Logo
42 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
