Question about LG 24 in. LDS 5811 Built-in Dishwasher
Pump constantly on and won't fill - LG 24 in. LDS 5811 Built-in Dishwasher
  • 901 Answers
First check whether inlet water is OK. Just for a trial manually pour water in the wash chamber without overflowing, to avoid spillage on your floor.
Run a empty cycle. If it works & drains check the inlet flow up to the pump, inside the machine.
Posted on Oct 04, 2010
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
99 legacy wagon won't fuel tank
most commonly the evap systems vent solenoid is plugged or inoperable causing pressure to build in the fuel tank as you fill up. this high pressure triggers the gas pump nozzle to shut off as it would if the tank had been filled. replace canister vent
Apr 06, 2013 | 1999 Subaru Legacy
Simpson esprit 500 wont stop draining
Is it possible the drain pump is running because the machine won't stop filling? Does the drain pump start running when machine start filling or doe it come on when machine is about full?
Jan 27, 2013 | Washing Machines
Land rover gas tank won't fill,
SOUNDS TO ME LIKE FUEL PUMP AT GAS STATION IS FLOWING FAST AND FUEL ISANT GETTING INTO THE TANK FAST ENOUGH SO THE PUMP SHUTS OFF TO PREVENT SPILLAGE
Aug 12, 2012 | 1999 Land Rover Discovery
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Whirlpool Clothes Washer Water Level...
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Washer does not fill with water
The problem is most likely that your drain valve is defective. If this happens, the water will pump out instead of circulating. There may also be something stuck in the drain valve causing it to stay open.
If you need more help, post a comment.
Thanks,
Tim
May 28, 2009 | Bosch 24 in. SGS43C12 Classixx...
Air conditioning problem
sounds like not enough freon or orfas valve is clogged. but most likely it is low on freon
May 05, 2009 | 2000 Oldsmobile Bravada
LG 24 in. LDS 5811 Built-in Dishwasher Logo
113 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
