Question about Vacuums
I need a belt routing for a toastmaster 3430b humidifier, looks like it needs two belts
There are actually 3 belts. One large belt from the fan to the pulley, and two identicle smaller belts that connect the pulleys. here is a pic I took of mine. Hope it helps.
Posted on Jan 25, 2011
I need to replace the belt
maybe the belt slip off or look on the brush`s for where the belt goes, should be on one side or the other.
Feb 15, 2014 | Kenmore Progressive Bagless Upright with...
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
The belt on the beater brush is too loose and the brush won't turn, I have ordered new belts and it still doesn't work!!
Look in your manual for the proper routing of the belt, there may be piece broken and missing without you realizing it. If this not the case, there has to be some kind of adjustment on this unit.
Oct 19, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Belt is torn
That is the problem. You can get the belt you need here:
Hoover Vacuum Belts
Dec 27, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum cleans properly,however smells like rubber. Nothing is caught in belt
You need to replace the vacuum belt. Even though the belt may look fine it is probably stretched or worn and slipping on the motor shaft and that is why there is a burnt rubber smell. You can get replacement belts here:
Replacement Vacuum Belts
Oct 31, 2009 | Vacuums
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Cleaned out hair,etc., but brush still doesn't rotate...makes a ratcheting noise.
You probably need to change the belt. Even though the belt my look okay it can be stretched and therefore not turning the brush. You can find the DC07 belt on www.vacbelts.com. If you have the DC07 with the clutch system you need these belts:
http://vacbelts.xps.convina.com/dyson-clutch-system-belt.htm
If it doesn't have a clutch then you need this belt:
http://vacbelts.xps.convina.com/dyson-flat-belt.htm
Oct 16, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Smart Vac Brush not rotating when touching floor
Sounds like either the belt wasn't routed correctly or the idler clamp asm.(part # 704194CSV) has a problem. There should be a diagram showing the belt placement either by the belt or on the inside of the cover.
Dec 24, 2007 | Vacuums
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
