Question about HP Photosmart C8180 All-in-One InkJet Printer
The book said put the cd in -label up- when it jammed- the device said put it in label down! How confused am I. What do I do? I can't get it out.
  • HP Master
  • 32,281 Answers
The book is correct. The inkjet will print on the label just like it will print on a piece of paper.
Posted on Oct 04, 2010
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
How do u use use lightscribe
Use the CD/DVD label maker program your burner should come with (or some other one). Create the CD/DVD label however you want, just don't be too extravagant... it may not come out very nice. Put your lightscribe CD/DVD media label-side down (upside down) into the tray and print away. Then you wait, wait, wait, and wait some more. Afterwards, you'll probably want to actually put some data on that disc.
Jul 27, 2011 | HP dvd1170e DVD-RAM Burner
I have 6 CD Changer in a 2002 SLK 320 with changer full of cd the player reads emty and will not play.
Have you tried putting the CDs in label-side down? My Alpine needs them to be label-side-up, but a friends changer (kenwood? I don't remember) needs them to be label-side-down.
Whichever way you've put them, try flipping the CDs to see if it makes a difference.
Feb 09, 2010 | JBL MCDC100 6-Disc CD Changer
Put new hard drive in ibm 570
you need to install the windows operating system to the new hard drive and transfer your files ...
if you still have the CD installer that comes with it when you bought the computer..use the CD with label operating system..then after you install the windows..use the cd with label drivers and application
Mar 15, 2009 | IBM Computers & Internet
I have a HP Printer C5500 When I try printing something on the CD/DVD Directly I get a Error saying that the printer doesn't support printing directly on the CD while the Printer is meant to print on...
I'm confused.. Are you trying to print to a CD/DVD Drive? Try the print job again, and choose the C5500 as the print device.. Seems that there may be a problem with the print device set-up , and you may have to delete the printer, and reinstall it.
If the printer is designed to print a label on a CD / DVD. then you will have to use the programs provided to accomplish this, as it requires formatting parameters be sent along with the print request. I.E. You can not cut and paste directly to a CD / DVD printer..
Nov 19, 2008 | HP Office Equipment & Supplies
DVD label label inner ring or center portion
If the center pops out you should pop it out. This labels are a bad idea in most cases and cause more harm than benefit. They come loose and get jammed. If its important to you buy a Lightscribe burner and DVDS.
Mar 18, 2008 | Televison & Video
Tape Jam
There may be a small piece of label cutting stuck in the gears. remove the label cartredge, you will see a white gear set between the pinch wheel and the print head. Use a micro drive or something strong and give the gears a little help while pushing the print button. You may have to do this several times. Be careful not to use too much force as this may knock a tooth off. Good luck. My Dymo continues to print prefet labels.
Mar 08, 2008 | Dymo LetraTAG Thermal Label Printer
HP Photosmart C8180 All-in-One InkJet Printer Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
