you have to change the jets to the "mains" gas, usually these are found inside the back cover of the oven, sometimes it is only a wrench adjustment on the gas valves theselves.. look in your manual on how to do this, and if you don't have the manual, you will need to order it from the terim company
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
