Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
One of the indoor units blows air which is not cooled. The evaporator coils are not cold. The second indoor unit is working normally. I have replaced the batteries in the remote control unit and reset the remote. I have also cleaned the filter and room temperature sensor but have not resolved the problem.
  • Anonymous Mar 22, 2014
    The coils are dusty and need cleaning, how do I do this
  • 24 Answers
Sounds like the metering device in the one that's not working is clogged and not letting the refrigerant flow through the coil.
Posted on Oct 04, 2010
  • howda123 Oct 04, 2010
    Thanks,
    how do I change or clean out the metering device and where can I locate it?
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
Bought a soleus air conditioner portable on and it worked great for week when drained it it has leaked ever since and not working as well to cool and sometimes gets e3 on displat
E3 error message which apparently means my air conditioneris working so well that it has internal frost. It then stops cooling the airand waits for itself to defrost. So every 5 minutes or so it would stop workingeven if the air temp was above 80 degrees. Also check one of this:
E3 Fault room sensor(s) (open or closed circuit)Code
E3Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control. Hope this will help you. Good Luck.
Jul 22, 2011 | Soleus Heating & Cooling
This is a heating and cooling company looking for a heating element or fuse link. The unit is blowing cold air when on heating setting. Is the heating element behind the evaporator coil?
You're right. The eating element always be behind the evaporator coil.But check whether your unit model has heating and cooling or cooling only.
Dec 14, 2010 | Fedders Y Chassis AEY12F7E Air Conditioner
Air conditioner not blowing out enough cold air fan is working but frost is built up outside and in on lines
Sounds like the unit may be Short on refrigerant, the frost can be sign the refrigeration is taking place on the pipework between the indoor and outdoor unit and not on the internal coil (evaporator indoor unit)
All the best
Jul 05, 2010 | Heating & Cooling
Our air con runs, on heat, and after a time cuts out, blows cold and makes a sort of hissing noise (but not a real hiss) and then shuts down. It then restarts after a couple of minutes. Is this normal?
Yes.Think of a heat pump as a A/C in reverce in cool indoor coil is cold&outdoor coil is hot.Naw indoor coil is hot &outdoor coil is cold&fan is pulling in cold air from outside.its going to iceup& go into defrost cycle.If your unit has a timed defrost every 30,60,or90min.(witch ever yours is set for)Defrost control board checks a sensor on cond.coil,if it is frozen unit goes into defost.You will here a swishing noise,iis the reversing of refrigerant.you will also notice the outdoor fan is not operating&at termanation of defrost fan will blow out steem.the other metod is on demand defrost.when coil freezes unit defrosts.
Mar 02, 2010 | Heating & Cooling
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
I have a GE window unit. I do not hear or see any water draining.. and I do not hear any change in the way the unit runs like I used to when it would blow really cold air. The air is cool - but not cold...
May need to wash out the out door coil. Normally spray through rear coil at about a 30 degree angle. try not to spray water directly into fan motor. If unit is freezing up it may be low on freon. if it is real hot out you may need to run 24 hour a day. High indoor humidity will affect its output also. could have weak compressor. check temp drop accross indoor coil. Shoud be 20 - 30 degrees in most cases cooler than room temp.
Jun 23, 2009 | GE AJCQ08ACB Air Conditioner
Amana heat/air conditioning pump
You are going to have to increase the amount of heat absorbed by the evaporator coil on the indoor section of your system. First change the filter. Second turn the power off to the outdoor section and leave the indoor fan running until all the ice on the evaporator coil has thawed this could take a few hours. Third you need to verify that you are getting adequate airflow across the indoor evaporator coil and the outdoor condenser coil both fans should be spinning at full speed and airflow should be unobstructed by dirty coil fins or debris Hopefully after you've done this you will have cold air blowing inside and the larger of the two lines entering the unit outside will be cool to the touch but not frozen or even frosted regardless of run time and the small one should be the slightly warm but not hot. If the larger line continues to freeze then it could indicate a number of problems but essentially your condensers cooling capacity is outrunning your evaporator coils ability to absorb heat from air stream circulating in your home.Hope it works out for you GL!
Jun 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
201 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
