Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
Two elongated blebs one third of the way down each side of the screen
  • 4,889 Answers
This is either a T-con board fault or a Panel fault. I would suggest that you try replacing the t-con first and see if it fixes the problem. If it does not then its probably time for a new tv as the LCD panel replacement is extremely expensive and you can get a new tv for that cost.
If you need further advice(for fixing it yourself) and I will tell you how to do it.
Sai
Posted on Oct 04, 2010
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
When try to view program on Windows 7 computer on youtube picture is elongated and top of picture is cut off. (only when using youtube) How to solve problem?
If you're using Firefox as your browser, click on the square with the three horizontal bars in the top right corner of the browser, the menu will open, you'll see 100% in the center of the second row from the top of the drop down window. To make the screen bigger or smaller click on the minus or plus sign to either side of the 100.
Mar 18, 2015 | Microsoft Windows 7
Sharp aquos LC-52D85U transparent line down the right side of the screen
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs' and can make sure about the fault.
Apr 19, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Lower speeds concern
a bleb on the tyre is a likley cause or a wheel bearing
Aug 17, 2012 | 2001 Ford Explorer Sport Trac
I have an hfd-135 air purifier but i can't tell if it's 110 or 220 volts.
View the electrical plug.
A 120 Volt plug has two elongated prongs on one side, with a smaller round prong for your ground, on the electrical plug.
A 220 Volt plug has two elongated prongs, but each will be opposing each other in the middle, but tilted towards each other at the top. Also, on a 220 plug, the third prong will not be round, but flat, and in a horizontal position.
Nov 15, 2010 | Health & Beauty
Elongated dark spot on LCD screen,speakers ringing
some units have replacable lamps for the backlight of the panel. take it top a qualified servicer.
Jan 23, 2009 | Televison & Video
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
NOTEBOOK PANEL FITTING
It fixed itself. I shut down computer and let sit overnight. On next reboot everything was back to normal!!!
Sep 23, 2008 | Acer Computers & Internet
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
105 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
