Question about Kenmore Washing Machines
The display is showing PF 28. - Kenmore Washing Machines
Kitchenaid model YKGSC308LSO is showing code PF
Press and hold the Start pad for 5 seconds until "Control Lock" appears on the display. Repeat to unlock, and "Control Lock" will disappear from the display.
Apr 19, 2014 | Kitchen Ranges
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
My TCL portable air con display panel show'PF' and it can not start.
PF power failure. Please check input has right voltage. If so, check fuse in PCB.
Oct 16, 2011 | Heating & Cooling
I have a whirlpool sf325lekq0 and it shows a code of PF on the dispaly and beeps. What does the PF indicate?
That would indicate a power failure you can press the clear off nutton and it should get rid of this PF displayed
Aug 31, 2010 | Whirlpool SF325 Gas Kitchen Range
Dryer will not start. Display shows PF
could pf mean particle filter and it needs cleaning
Jun 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
May 27, 2009 | Frigidaire Dishwashers
Washing Machines Logo
22 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
