Question about Car Audio & Video
I need to connect 12v neon to 12 v plug
Rite well i would like to wire my neons that are 12 v ment for a car can i just wire it to a 12 v acdc is it safe as i dont know
thanks adam
    Problem Solver:
  • 7 Answers
Well id like more information but lets do something. I got neons under body and inside. All of them are connected to my fuses. what you need to do is connect the ground cable to the fuselage of the car(hidden) so it looks perfect. Then connect the red cable (or positive cable) to any switch where - is or so so you kow what way is to turn it on(buy the switch anywhere it wont cost more than 4 bucks). Then get some extra red cable 26 or 28' would do and put it to around any fuse and from that well go and conect the other end to the O, the switch side where off is selected. Thats it, really simple. :)
If more questions please ask, and make sure neon works before installing.
Posted on May 27, 2008
1997 dodge neon battery cables where do they hook up and lead to
on any 12v vehicle system, any battery wire connected to the chassis or motor block will connect to the negative terminal on the battery the other typically red insulated wire connects to the positive terminal.
Mar 17, 2016 | Dodge Cars & Trucks
Car momentarally shutters at all speeds and gears more and more frequently after it is warmed up. You can feel it slightly at idle.
2003 neon shaking after changing both right motor mounts ...
www.topix.com > Dodge Neon
Mar 10, 2012 - ... News Offbeat Stars! Topix > Dodge Neon > 2003 neon shaking after changing both. .... Google dodge neon engine alignment, and some sites will fill you in better. Reply ». Report Abuse .... 95 neon oil leak? (Oct '08), Oct 22 ... dodge neon engine vibration
Nov 10, 2012
2004 Dodge Neon SXT Problems
Jan 8, 2011
02 neon vibration under acceleration
Jul 21, 2007
97 Neon Idle rough
Jan 18, 2007
More results from www.topix.com
Oct 29, 2015 | 1995 Dodge Neon
Where can i find a wiring diagram for neutral safety switch for 2003 neon
The DK BLU/WHT wire from 15A fuse 10 in the fuse block connects to terminal 2 of the brake transmission shift interlock solenoid. The WHT/PINK wire from the brake lamp switch connects to terminal 1.
Apr 09, 2013 | 2003 Dodge Neon
Engine runs rough after a few miles
Easy way to check plugs wires while driving, get 4 or 6 small neon lamps depending on how many cylinders,the neon lamps used in appliances to show they are on are good NOT LEDs.
Remove resistors from neon and connect one side of neon lamps together and earth to body, take other side of each lamp and solder long single telephonr wire and wind about 10 turns around each plug wire insulation a little way from plug leave end of this wire disconnected. make sure the end of wire does not earth anywhere on body leave unconnected. the high voltage going through plug wire will induce enough voltage to fire neon and show plug works if one neon does not flicker as plug fires it the bad one.
This will only show electrical misfire not injector problem.
The best time to do this test is at night neons will flicker bright at night. As a mechanic how to check injector and injector voltage.
Jun 28, 2017 | 1994 Isuzu Rodeo
I need a plug in that plugs into the instrument cluster in a 96 dodge neon, The wiring came out of the plug Help?
you can get one cheap from a junkyard for same year and the colors will match for the wires.
if you know how to solder that is a help, will give you the best connection.
i am not sure if the dealerships carry the pigtails anymore for a 1996
Sep 18, 2011 | 1996 Dodge Neon
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
(Gray Plug)
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
1996 neon the speedometer and the fuel gage do not work also the backup lights do not work help
I have a similar issue with my 1997 Neon. My fuel gauge works, but my speedometer only works when it feels like it (jumps and then drops to zero) and once my whole cluster didn't come on. I've found this (http://forums.neons.org/viewtopic.php?f=22&t=118450) that I'm going to try when I get a soldering iron. Also I just discovered my reverse lights don't work either and it's not the bulbs, my best guess is the Neutral Safety Switch because I can start my car in drive and reverse.
Aug 04, 2009 | 1996 Dodge Neon
1998 Dodge Neon 2.0L SOHC
Do you have eng light on and what mileage do you have and have you ever replaced the timing belt on it?
Jan 04, 2009 | 1998 Dodge Neon
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
