Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Our Kenmore 795.75202402 Refrigerator w/bottom freezer has stopped cooling. Everything in freezer has thawed. Started making clicking noise yesterday, at intermittent times. This item was purchased in 12/28/2006.
dididsaythat
  • 291 Answers
SOURCE: KENMORE REFRIGERATOR
Need a model # ... mostly likey better to just replace ice maker if that old.. 12-15 if same age as ref.
Posted on Sep 07, 2007
  • 128 Answers
SOURCE: Refrigerator does not produce ice or water.
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Posted on Mar 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Refrigerator Trio display panel read
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Posted on Sep 30, 2010
SOURCE: I have a Kenmore 596.72232200
Try manually defrosing the coils in the back of the freezer to regain air circulation around the coils then plug it back in to see if it gets better. If this doesn't help. It could be a defrost issue or thermostat issue.
Posted on Feb 19, 2011
Refrigerator wont cool but freezer does
The problem is the Ice Dam inside your Freezer. You have to defrost the Freezer (making sure to completely dry the Bottom of the Freezer and more importantly the DRAIN TUBE)...
Jul 20, 2014 | Frigidaire FRS6R4E Side by Side...
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Makes clicking noise every two minutes. freezer is thawing and top is not cooling
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 30, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerator stops cooling
Your defrost system is bad. When the unit freezes up, the air flow shuts down and you don't cool. When you turm it off, it thaws out and starts to work again. We have parts so give us a call if you like. Hope this helps! Ella
Aug 18, 2009 | Kenmore 63222 / 63224 Bottom Freezer...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
INTERMINENT BUZZING NOT COOLING
from your description it sounds as if the compressor is not starting up. the buzzing noise usually occurs approx. ever 3-5 minutes and is followed by a click. this indicates either a bad start relay or a stuck compressor. and from the model you listed it is most likely the compressor. if the unit is under 5 yrs old it should still be in warranty thru sears.
Thanks for using FixYa Peyton
Feb 18, 2009 | Kenmore 71812 / 71814 / 71819 Bottom...
Frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Jan 19, 2009 | Kenmore 73503 Stainless Steel Bottom...
Freezer not working
sounds like the clicking noise could be the overload on the compressor. pull off grill cover on bottom front of refrigerator check to see if condenser coil if blocked with lint and dust if it is clean it throughly it could cause the compressor to overheat and cause the refrigerator to thaw and the overlaod to make a clicking noise. hope this helps you out
Dec 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Help
Well mine went through some of the same thing the fridge put out less and less cold ait and the freezer started to thaw just a tad on max settings. Mines about 8 years old and a kenmore.
Made the decision on an opportune time when Sears was having an additional 10% off sale..... my problem will be fixed ina bout 2 hours when my new fridge is delivered. The sad truth is (I now its cliche) they don't make um like they used to. Last fridge i had lasted nearly 20 years. Now if you get more than 5 out of an appliance you're doing good. Good luck but it sounds like the compressor died. You'll either need an expert to come out (think they have a min fee of $100 or more) or repalce it.
Jun 17, 2008 | GE GSH25JFR Side by Side Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
