Question about HP Office Equipment & Supplies
My scanner doesn't work...when i press scan button it says preparing for the scan and than it says scan problem!!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 196 Answers
Disconnect the Scanner or Printer from the Computer .Then uninstall the printer or scanner software.Restart, your computer,then re-install your software restart your Computer try scanning
Posted on Oct 04, 2010
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
I can't figure out how to scan something. The Wand turns on, but it won't start scanning. I even tried the white balance calibration?
Hi Karen,
Do you have a micro scan disk inserted? The scanner will not work without one. Insert the disk in the slot next to the Format button. Turn the unit on then press the format button to format the disk. To scan a document, you press the scan buttton once, then release the button. Slowly move the wand over the document to be scanned. When you have finished scanning, press the scan button once again.
Hope this helps,
Marcus
Nov 02, 2010 | VuPoint PDSST410VP
My child played with scanner & now it is a mess i have tried the turning it off and then on then program and number 1 but that doesn't seem to be working correctly - i have read the manual but can't...
If all else fails, you can INITIALIZE the scanner to return it to the original factory settings. This will erase everything that you've programmed into it though, so be prepared to reprogram all your frequencies/systems. To INITIALIZE the PRO-164:
- Turn the scanner OFF, then turn it ON again. "Multi-system Trunking Scanner" will appear on the display.
- While "Multi-system Trunking Scanner" is displayed, press the "0" key.
- Press the "1" key.
- Press the "ENT" key. "Initializing please stand by" will appear on the display for about 5 seconds. The process is complete when the display switches to "M000" and "Bank 0 CH 00".
NOTE: Do not power the scanner OFF until the INITIALIZE process is complete.
For a comprehensive database of active frequencies and systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
May 23, 2010 | Radio Communications
HP OJ 6500 with windows7..Scan button on scanner is not working.
The reason that you are unable to scan through the printer is, you are missing HP full feature software and driver.
Please download and install it from the below link
DOWNLOAD
Regards
Rizwan
Feb 13, 2010 | HP Officejet 6500 Wireless All-in-One...
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
We cannot get the scan to operate on the hp officejet 4315 all in one printer
When you lift lid to scanner pad, does bulb light up? It should also move slightly as if to prepare for a scan. If these things do not occur, something is definitely wrong with the scanner itself and will require a technician to service.
If bulb does light and carriage moves, then you should try using the buttons on printer control panel and try to use software on computer to try a scan.
If the control panel button works, then it's a software issue. You can try different software like HP Directory or any photo software with input from scanner feature.
If software works, but control panel doesn't, you'll need a technician to fix the panel.
If neither work, we are back to a problem with the physical scanner. That requires a technician to look at it.
Oct 05, 2009 | HP Officejet 4315v All-In-One InkJet...
Scanner not working.
I had a simular problem with my HpScanner. What I found myself, was the computer stopped recongnizing the program after a few uses. Check your computer programs and see if it's still in. Then if its not, reload it, or simply restart/reboot your computer and see if it recongnizes it then. I believe its a glitch in the programing from the scanner itself. Also just always check if your connections are easily tugged on, may have come loose. They may look connected, but the littelest separation would cause it not to function either. Let me know what happens.
Aug 12, 2009 | HP PSC 1210 All-In-One InkJet Printer
Scan button do not function
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
Nov 23, 2007 | Symbol MC1000 Barcode Scanner
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
129 people viewed this question
Seeker5211
Seeker5211
