Question about Frigidaire FTF530FS Front Load Washer
I bought in Houston (Texas) in 1992 the described below FRIGIDAIRE washing machine FRIGIDAIRE WD 5891 951111192 ( with 16 programmes ) capacité 5Kg spin motor 800watts PROGRAMATEUR KEMO KEUR 51600 5900 TYPE 900 Z8FILLINGMOTORE10-16 TYPE 914 7917 This machine has been and it is still working very well, except that since few days, at the end of washing cycles, it spins very slowly ( 60 /minute) . As a result, not much water is extracted from the clothes which are very wet at the end of the spin cycle. Note that I made several tests with very small load (2 shirts only ) to avoid having the machine out of balance. Also note that there is no problem from the water pump which is working correctly since no water is left in the machine at the end of cycles. Could you advise? G. SAUNIER
  • 10,865 Answers
Hello. It is unusual to have a 1992 washing machine still in service. Since the spin cycle is the problem, begin by testing the motor coupler. To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt, a worn clutch or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Seek the assistance of a qualified appliance repair technician. Lastly, water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Oct 04, 2010
I have a LG wd-1025 washing machine and the start button wont work and does this intermittently
REPLACE SWITCH! If the machine persists after replacement then have the programmer checked if it is mechanical and the main logic board if the machine has electronic programming functionality
Jul 31, 2015 | LG Washing Machines
Looking for schoolbus roof-top AC installer in Houston, Texas.
You can get lots of roofing companies in Houston TX. Just like CM Construction Remodeling, It is near to your location and helpful for you, get a fast response with reasonable price.
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Find repair service in Houston to fix my T-mobile sidekick
THE SIDEKICK HAS A LOT OF ISSUES SO I WOULD SUGGEST THAT YOU CALL THE SIDEKICK SPECIALTY DEPT AT 611 FROM YOUR HANDSET!!!!
Dec 01, 2009 | T-Mobile Sidekick® 3 Cellular Phone
It smells like musty water inside the machine and is leaving that smell on clothes and towels
it is very good q
advice in secret do 2 things
1-{ washing without soap without clothes in maximum temperature like 95 oC in cotton programm } do that every mounth
2- after complet any washing programm leave door of m/c open for just 15 minutes
thanks
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Hoover SE230 Programmer rotating
Hi there, my washing machine was doing the same as the one you have mentioned.
I bought a replacement timer from the website highlighted below. It has done the trick and every programme works properly now.
A competent DIY person can change one of these easily and will take about 30 minutes to do.
The new part looks slightly different but it carries the same part number.
The price £24.99 + £4.98 delivery.
http://www.4hoover.co.uk/cgi-bin/product.pl?PID=723224&section=46246&brand=&model=SE230&path=45786,46246
Mar 05, 2008 | Hoover SE230 Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
66 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
