Question about LG Computers & Internet
I m facing a monitor problem, that monitor is basically of (LG CRT) its picture is become small by four sides.
    Sergeant:
    Champion:
  • 293 Answers
Find the button menu and press.select the harizontal size adjust ment and. next is the vertical size adjustment.
Posted on Oct 04, 2010
Flickering,shattering and small display size
hit your MONITOR lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some monitors on main board ( also on CRT circuit board ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......monitor main board & CRT circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )..............
Apr 19, 2011 | LG Studioworks 700S 17" CRT Monitor
17'' samsung synchmaster 794MG model display but screen shrinks from all sides ,After few seconds display becomes very small just about in single inch size .
Apr 14, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
My LG 500G CRT 14inch monitor become rotate from height and width and can't solve from menu item please help me and give me the solution.
Hi there monitor rotated or the Menu/ program file are going on top side? Please let me know that, also tell me which operating system you use.
Feb 01, 2011 | LG Studioworks 775N 17" CRT Monitor
MY LG 500G CRT 14" monitor is become faded and very white color graphics(nothing seen with out white color) after 1 or 2 sec. when i re start the monitor i can see some very brigh graphics then again...
open the monitor there is a movable preset attached to EHT rotate that preset by screwdriver in active on condition of monitor reduce the brightness to satisfactory level
Mar 29, 2010 | LG Studioworks 775N 17" CRT Monitor
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
CRT monitor becomes yellowish..
When any dust goes inside your monitor .......you will get these things.......... remove it , it will work fine
Jan 12, 2009 | LG Studioworks 45 14" CRT Monitor
Blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Problem LG XNOTE 229QA2
Please try and external monitor if the picture is OK then you are having LCD problems. I dont know for you but over in the States here: http://lcdrepair.net They maybe, are able to help you.
Sep 29, 2007 | Computers & Internet
Peculiar Problem in LG studioworks 563N monitor?
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
Mar 28, 2007 | LG Studioworks 563N 15" CRT Monitor
Computers & Internet Logo
55 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
