Question about LG LMVM2085ST Stainless Steel 1100 Watts Microwave Oven
I have an LG Microwave, model # LMVM2085ST and every since I've owned it the turntable makes this popping sound at about 180 degrees into each turn. I've tried taking the turntable out and putting it back it several times. I've made sure that the rollers are on track with the turntable glass, now I am at my whits end as to what should be done next. Please help if you can as this is very annoying. The popping sounds like the turntable is trying to come off track of the rollers.
MicrowaveSvc
  • 9085 Answers
SOURCE: smoke coming out of microwave
I would contact LG / Goldstar.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Posted on Aug 18, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: How to turn off annoying beep sounds of alert and programming
First of all, microwave ovens do not emit ionizing radiation.
The only risk from any leakage is a burn.
Generally, microwave leakage only occurs when the door / door seal is loose or damaged or there has been an improper repair attempt.
You can select a model which lets you turn the beeper on and off by looking for that feature as you shop manufacturer Web sites, or in the store ask the clerk to pull the manual for you to examine, or contact the manufacturer's help center, support center, or FAQ.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. LG / Goldstar owner's manuals can be downloaded here.
If you're interested in other brands, please reply back and let me know. I'll be happy to post contact info.
Posted on Sep 28, 2008
JSEhandyman
  • 368 Answers
SOURCE: LG Microwave LMV1650st wont heat food
Hi eb6181,
If it's within warranty, I'd exercise that and get it fixed.
Usually, if it appears to run, but isn't heating, the magnetron has gone bad. It's not a cheap part, and not really a DIY (do-it-yourself) operation. If your warranty covers the part, that will help a lot.
Even if not within warranty, I'd have an authorized service center do the job. They should have a list of authorized outlets with your manual and other literature. They can also give you a quote as to how much it will cost - - only you can make that call.
I had a magnetron replaced once, it was spendy, but ~20 years ago, microwaves were a lot more expensive than they are now.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 30, 2008
  • 13 Answers
SOURCE: how do i turn the turntable off?
You dont.
You can use spacers(nonmetalic of course) to raise the platter high enough to disenguage the drive. You can also shift the tray to one side on some models.
Posted on Jan 26, 2009
ginko
  • 19396 Answers
SOURCE: Oven does not heat and makes loud, continuous "hum" when turned on and related to turning of oven table.
est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Microwave oven model lmvm2085st how do you set the clock
Good afternoon Chris.
To set the clock:
  1. Push the [Clock] Button
  2. Enter the time with the keypad. For 8:37, type 8 3 7 for example.
  3. Touch [Start/Enter]
  4. Press [1] for AM, [2] for PM.
  5. Press [Start/Enter] again to finish.
You can download the manual on this page at the LG website:
http://www.lg.com/us/support-product/lg-LMVM2085ST
Hope that helps, and good luck!
Nov 18, 2015 | Microwave Ovens
How to install turntable motor in kenmore 72169072900
You can find helpful exploded views and find parts by entering your full model number (72169072900) at the Sears Parts Direct Web site.
Remove the glass tray and turn the oven on it side to get to the bottom base plate.
If you look at the diagram titled "base plate parts" you'll see the access panel on the bottom in the center that has to be removed to get to the turntable motor screws.
On some models, you have to cut the metal strips holding the panel in place, then during reassembly use a screw to reattach it. In some cases, the cover has to be rotate 180 degrees before reinstallation.
You then unplug the connectors on the turntable wires, then remove the screws holding the turntable motor, gently lift it out and also ease the turntable off the motor shaft.
Jan 29, 2013 | Kenmore 62642 / 62644 / 62649 Microwave...
Lmvm2085st glass tray not rotating
The problem is most likely one or two door switches are bad, usually caused by food partical build up, replacement needed.
Mar 17, 2012 | LG LMVM2085ST Stainless Steel 1100 Watts...
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
LG over the stove model lmvm 1935
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
In some cases, cleaning them helps. Lubrication is not recommended.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
Lg lrm 1250 microwave
Some over the range models allow you to turn off the turntable via the keypad. Counter top models usually don't.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 12, 2008 | LG LRM1250 Microwave Oven
LG LMVM2085ST Stainless Steel 1100 Watts Microwave Oven Logo
66 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
