I have a Samsung R60plus, CD/DVD tray will only open manually, and will not play anything
    Sergeant:
    Champion:
  • 326 Answers
Check the control panel - system - device hardware list to see if the pc see's the drive. Sounds like it has died, but as a last resort, if the system see's it, uninstall it and reboot. install the driver for it when the system detects it. Else replace it.
Posted on May 28, 2008
Replace cd player
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Apr 16, 2013 | Samsung Computers & Internet
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
Please help me, i have a samsung r60plus, cd dvd rom cannot be detected, what should i do?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Jun 03, 2011 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Need a dvd-rom/rw driver for my laptop samsung r60plus win7
Usually they are plyg n play. If it don't work go to syetm and rollover driver. If it doesn't you could have a bad DVD player.
May 28, 2011 | Samsung Computers & Internet
HOW TO FACTORY RESTORE SAMSUNG R60PLUS laptop
hi
factory setting in bios
-set default
factory setting about program
- put the original CD or DVD (restore) in your CD drive
an restart the laptops
make sure that your boot sequence is CD drive
if it is not change it in bios setup
Jun 04, 2010 | Computers & Internet
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
