Question about Kenmore 43142 Front Load Washer
Black marks on clothing
I am getting black marks on my clothing, looks like grease to me. I did have a black crud around the fabric softener compartment, so I took that all apart and cleaned it well thinking that would solve the problem. It didn't. A Sears repair man came and thought we should run a "clean" cycle with bleach and hot water and that should solve it. If it didn't, he suggested a new tub and basket (basket covered by warranty, tub not) which would cost me around $500. He didn't seem to know what the problem was. We ran the clean cycle with hot water and bleach. The problem is still occurring and just when we think it is okay, we lose more clothes.
Any ideas?
Scott
  • 1 more comment
  • kwlewis May 28, 2008
    I have had the same problem with black marks on clothes. I was told by another appliance place that it was probably mold and mildew buildup in the rubber boot that seals around the door. There definitely was black crud in the crevasse but even after cleaning it very well it seems to happen again in a short amount of time. Very frustrating that Sears Techs. can't seem to figure it out if you can even get to talk with one.
  • bpsstfixya May 28, 2008
    Problem is the bearings seal has gone bad spilling greese into your clothes drum. We have same problem and apparently this model is known for the bearing seals going out and then then the bearings go (our spin cycle has slowed to a crawl)...repairs are estimated at $600 or more...uggggggh!
  • kwlewis May 29, 2008
    Had a non-Sears repairman out today. He said the black marks are grease caused by the failure of the rear bearing on my Kenmore front loader. Cost to fix would be about $400. Have opted to go with a new or used washer other than a Kenmore since this is the second major problem with this washer. At this point I would not buy a Kenmore anything ever.
I have had this problem with my front load washer and have been able to solve it by cleaning the buildup off of the lower part of the glass window on the door.
Posted on May 28, 2008
My simpson eziset 750 is leaving grease marks on clothes after wash. Whats wrong?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
Eziset 750. Why is it leaving grease marks on clothes after wash?
It leaves holes and looks like black rubber on it
the black rubber is most likely fabric softener build up. The hose are the marks of the bowl perforations. Once this black 'stuff' builds up from the over use of fabric softener it could mean the end of the machine. The way to try and get rid of it is to wash an empty load in hot water with Epsom salts. This will loosen the black grease but be careful as some loads further on, large amounts could release and mark you clothes. If the bowls can be removed from the machine they could be scrubbed clean but this is a costly exercise. Tip from now on do not ever use fabric softener. end of story. Use low sudsing soap in your washer whether it be a top or front loader. www.thewashingmachineman.webs.com good luck
Feb 23, 2011 | Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Black streaks on my laundry
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Jul 24, 2009 | Frigidaire ATF6000ES Front Load Washer
hi, i think you will find the bearing on the drum is about to fail, you need to replace it, hope this helps
Feb 10, 2009 | Washing Machines
Sometimes my clothes come out of the washing machine with splotches of fresh black grease on them.
Clean out the gunk from the fabric softener basin in the center of the machine in the tub. The gunk gets on the clothes and then gets baked in the dryer and turns out black grease.
Jul 22, 2008 | Washing Machines
Sounds like grease or oil from transmission may be leaking and finding its way into tub.
Nov 03, 2017 | Kenmore 43142 Front Load Washer
Marks on white clothes
if the machine has become more noisy of late, the the oil and greease out of the bearing has done this. Which means a heavy bill. appliance doctor
Jan 28, 2007 | LG WM-1832C Front Load Washer
Kenmore 43142 Front Load Washer Logo
200 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
