Question about Nokia 6070 Cellular Phone
When i connect to usb cable to my phone it says enhancement is connected,afterwards enhancement not supported what i do for sove the problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 110 Answers
Get correct cable which is compatible with your cell phone,you can check which cable type is compatible with your phone on nokia website by selecting your phone model,write down cable model then check its on your local shop or you can buy its from ebay
Posted on Oct 04, 2010
6300 Cellular Phone: i have nokia 2700.when i connect thgh data cable u...
firstly u conect with pc suite.after few min.its shows connected.change access point name
May 18, 2010 | Nokia 6300 Cellular Phone
Iwant to connect nokia 3600 to lap top to be able to download photographs
There is two main ways that you can transfer photographs to your laptop;
  • USB 2.0 Full Speed for rapid music transfer Nokia Connectivity Cable CA-101 - High-speed data transfer
    This micro USB cable provides high-speed USB 2.0 data transfer rates, and enables charging your compatible device or enhancement from a laptop or PC USB port.
  • Bluetooth 2.0 with stereo audio profiles for wireless music listening and control.
Jan 20, 2010 | Nokia 3600 slide Cellular Phone
I cant connect nokia 2630 to my system using a usb cable
The Nokia 2630 doesn't support USB cable connection unfortunately. It only supports FBUS cable connection which can be used to flash the phone.
The only way to connect the phone to your system is to use a Bluetooth dongle.
Aug 31, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Camera not supporting
the problem is with a chanel cam of the flex cable its the part that connects the keypad and camera to the lcd u need to chnage it!!
plz do rate this post
Nov 04, 2008 | Nokia 3250 Cellular Phone
Data cable does not work
Try the following
  • A different USB Port
  • Test on a different phone to see if the connection port is broken
  • Try a different cable to see if the cable is faulty
Sep 16, 2008 | Nokia N72 Cellular Phone
Enhancement problem
firstof all,,, are you a cellphone technician?if yes just check first the connection in the head set area! use a tester if the connections are ok!
Sep 02, 2008 | Nokia 6233 Cellular Phone
HELP MEEEE!!!
You need to reprogram your phone. If you have the usb cable you can do it yourself.
http://direct.motorola.com/Hellomoto/uk/support/SoftwaresNDrivers.asp
  1. Your phone can upload and download files when connected to a PC running Windows 2000 and higher.
    Note: Mac is not suported.
  2. Open the flip and turn the phone on.
  3. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  4. On your phone, press Yes to use the phone as a portable USB storage device.
    NOTE: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  5. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  6. Drag and drop files between your computer and phone.
  7. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  8. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts.
i found this on a another fellow fixya member's page.
Have a nice day!
Jun 12, 2008 | Motorola Mobility W375 Cellular Phone
My phone does not support the data enhancement
i have the cable adapter which is ca-62. but when i connect my phone with my pc then pc shows that it is an unknon device. so what should i do?
May 23, 2008 | Nokia 6020 Cellular Phone
Nokia 3586: "enhancement not supported"
Try to download the latest Nokia PC Suite, and the latest drivers from the phone.
Nov 09, 2007 | Nokia 3586i
Nokia 6070 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
