Question about Panasonic KX-T7730 Corded Phone
Hold sound in loudspeaker
Please tell me how to remove the sound of the hold of the loudspeaker of my telephone since for this motive I have it unhooked
  • Anonymous Jun 10, 2008
    θ?­λω να σταματ?®σει η μουσικ?® , η οπο?¯α συνεχ?¯ζει και πα?¯ζει αν και ?­χω β?¬λει το ακουστικ?Œ στη θ?­ση του !
    Problem Solver:
  • 6 Answers
While the phone is idle, press 1 on the dial pad.
Posted on Jun 02, 2008
Unmute
If it is in an Apple product, I would not know. But for Windows based or Linux based computers, locate the icon of the loudspeaker on the task bar (at the bottom right in Windows, or the Top right in Linux). Click on the loudspeaker icon, and adjust the volume or remove the X on the speaker.
Dec 21, 2013 | Apple MacBook Air
Loudspeakers crackle
The audio output section circuit should be troubleshooted. The most possible cause is with its audio output IC itself. Check for any loose solder terminals to this section.
Jul 15, 2012 | Philips 42PFL5332D 42 in. LCD Television
How u use loudspeaker in samsung champ.and how to subscribe games in samsung champ.
MY PHONE LOUDSPEAKER LOCK
AND PHONE TELLING ME PRESS THE HOLD KEY TO USE IN CALL FUNCTIONS
Sep 20, 2010 | Health & Beauty
Dropped Tea in E63 loudspeaker not working...Kindly Help
I think your mobile ringer no working it need to be clean. So if you have any Mobile repair worker to near your home go to over there & tell him to make it clean but carefully then check your mob. ringer.
I hope than it will work very fine as working before...
Jan 25, 2010 | Nokia E63 Cell Phone
There is no more sound from my Toshiba laptop loudspeakers
Try to use different players like windows media player and winamp
and check if it is not muted by standart software or 3rd party
Mar 19, 2009 | Toshiba (4CH-VOUT) Sound Card
Sound problem
hello
no there is not any good software available in net for ur mob even if u use it and dont not work well u may even loose ur warrenty ..... so first concern it wit nokia else check it out wit any local shop
thank u
Oct 22, 2008 | Nokia N72 Cellular Phone
Replacing the speaker
follow instructions to step 8 (with thanks to Anny for posting it)
http://www.annystudio.com/misc/ipaq4700/
With the motherboard removed, you will see the back of the speaker pictured in step 10.
I seem to recall that the 'official' replacement loudspeaker (17 UKPounds) looked identical to one taken out of an old Nokia mobile telephone I had lying around. I didn't try it - so I don't know if it would work but the DC resistance across the terminals were about the same.
The loudspeaker in the hx4700 is notoriously unreliable and can apparently be damaged by some software titles. I recall that HP published a firmware patch some years ago. I have also found that it is easy to miss the stylus receptical in the top of the device and it is possible to inadvertantly jam the stylus into the earphone socket. This can cause damage to the switch contacts in the jack socket that disconnects the loudspeaker when headphones are used giving the false impression that the loudspeaker itself has failed. I checked this with a multimeter before changing the speaker. In my case the contacts were OK but I doubt that I would have been able to repair the switch contacts without some serious soldering iron weilding.
A final note. The ribbon connector for the screen is VERY fragile. Be ultra careful when removing it.
Hope it helps.
Steve
Sep 02, 2008 | HP iPAQ HX4700 Pocket PC
Mute voice call
maybe you have your phone on mute, to where you can hear them but they can't hear you? Next time you make a call, tell that person to hold on and if they can't hear you, look through the option menus you can access only when you're in the middle of a call. Otherwise, contact the phone company and gripe.
Jul 28, 2008 | Nokia N95 Cellular Phone
Sound
With the handset on hook press 1
Please vote if this answer was helpful.
Thank you.
May 27, 2008 | Panasonic KX-T7730 Corded Phone
Volume
Volume control
• When you have an active call or are listening to a sound, press o) or (o to
increase or decrease the volume level, respectively.
Voice volume icons:
- for earpiece mode,
- for loudspeaker mode.
Loudspeaker
Your phone has a loudspeaker for handsfree use. The loudspeaker allows you to
speak and listen to the phone from a short distance without having to hold the
phone to your ear, for example, having it on a table nearby. The loudspeaker can
be used during a call, with sound and video applications, and when viewing
multimedia messages. Sound and video applications use the loudspeaker by
default. Using the loudspeaker makes it easier to use other applications while in a
call.
Apr 02, 2008 | Nokia 6600
Panasonic KX-T7730 Corded Phone Logo
64 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
