Question about Maytag Dependable Care LAT9706
Maytag LAT9706AAM Washer - Spin Cycle problems
The spin cycle seem to work at random. Some times it works fine but most of the time the timer knob moves through the spin cycle, we hear clicking noises but the washer does not spin and the cycle ends with the tub full of water.
  • 4 more comments
  • Babu52 May 27, 2008
    Thanks for your help. Do you think spraying some thing would help clean up the contacts?
  • Anonymous Mar 13, 2014
    All cycle choices on the selector will not work. Only spins at times.
  • Anonymous Mar 15, 2014
    Washer won't spin or drain at the end of the normal cycle but it will work when I put it on "drain and spin"
  • Anonymous Mar 24, 2014
    My washer was working fine but now it is leaking from underneath on the last cycle
  • Anonymous Mar 26, 2014
    Normal cycle stops rest are fine
  • Anonymous Mar 29, 2014
    i close the hood to the washer but it doesn't spin and its full of water and the timer doesn't move either
  • 525 Answers
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
Posted on May 27, 2008
  • David Emmel
    David Emmel May 29, 2008
    I would not recommend spraying any fluid into or onto the timer as this ccould cause more serious electrical problems.
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
What will cause the washing machine to not spin fast enough to spin the clothes dry or not spin the fabric softener out of the agitator cup?
If your towels are coming out the dryest it is probably a problem with it being off balance. Did you make sure that the clothes are even placed in the washer. If you have a bunch of heavy stuff on one side and light stuff on the other side it could cause the same problem.
Dec 05, 2012 | Maytag Legacy Series Top Load Washer
We have this washer and it works fine until the spin cycle. It won't spin unless you hold down the knob on top. Do we need a new knob?
Behind that knob is a timer....the switch in that timer is bad and will only make contact when you hold it down.
Replace the timer and you will be good...
Aug 18, 2010 | Maytag MAV7600 Top Load Washer
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
Jul 11, 2009 | Maytag Dependable Care LAT9706
The washer will fill up with water but won't complete the cycle or drain. This has happened before, and I would spin the knob a few times and switch the load size selection. It always randomly started
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
May 27, 2009 | Maytag Washing Machines
Washer will not spin on the regular cycle but does on the delicate cycle??
Dear friend,
ngfam at you service!
You have an electronic problem and have no choice but to call service!
If the washer is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide -USA
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 28, 2008 | Maytag MAV3905EWW 13 Cycle Washer
Have maytag washing machine model no LAT5006AGE serial no 25000887yk which will not spin belt appears ok but motor is not working for the spin cycle. It washes fills drains all ok do you have a solution...
Possibly a lid switch. The washer shouldn't spin if it thinks the lid is open. Possibly a wiring issue. Check the wiring to the motor. If those check out it could be a problem with the timer. Sometimes bad contacts in a timer can be checked by turning the washer on in the spin cycle where it should be working and wiggling the timer shaft up and down and around without turning the knob. If the washer starts and stops, you've got a bad timer.
Jul 20, 2008 | Maytag Washing Machines
Washing Machines Logo
650 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
