Question about HP Pavilion dv6000z Notebook
Dv6000 laptop the pboblem is screen has multipal display
Can I switch out the screen to my hp g60 535 dx laptop with a screen from an hp dv6000 laptop
That will be impossible. The screen from the HP Pavilion G60-535dx is a 15.6 CCFL LCD while the one of the DV6000 is 15.4.
I suggest buying a new screen for the DV6000 if you need to. Or go online and trade the screen of the HP G60 and use the fund acquired to get a screen for the DV6000.
Hope this helps.
Oct 28, 2014 | Computers & Internet
Hp dv6000 laptop screen blurry
Hello Al,
I hate to inform you but the graphics chip in these laptops are known for doing this. HP is aware of that. Every time some one brings me a Hp Dv6000 laptop about 75% of the problem is the system board or overheating issues.
First try cleaning the laptop screen with laptop screen cleaner
Walmart LCD Display Screen Cleaner for TVs Computers and Cameras
if its still blurry connect a external monitor to your laptop to see if the display is blurry on the external monitor (to get to toggle the video from your laptop you will have to press the Fn key + F4)
If its still blurry then its the graphics card or chip needs to be replaced. They are all integrated with the system board / mother board.
If its clear and images are good then the laptop screen will need to be replaced. hope that helps.
Jan 21, 2014 | HP Pavilion dv6000z Notebook
My HP Pavilion dv6000 screen goes dark when booting up.
Video card/drivers/wiring. Have it starting in safe mode. If the simptoms are similar, have it checked in service. You may need to replace video card.
Mar 06, 2013 | HP Pavilion dv6000z Notebook
A thin horizontal black line has appeared just below the centre of the screen on my hp pavilion dv6000 (running vista), there is no change when i gently press the screen, so i think the problem isnt with...
As the symptom you indicated above it is the problem with your LCD Panel. It is to be replaced to sort out this issue. To check and confirm the functionality of your Laptop motherboard plz check the Laptop with external display.
Nov 25, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My HP Pavilion DV6000's display got damaged. i wanna knoe how mch appv it will cost if i get it repaired. my laptop is not under d guarantee period. plzz rply ASAP.
Finding the replacement is easy;
http://www.amazon.com/Glossy-Laptop-Screen-Pavilion-DV6000/dp/B002LC7C3I
Replacing is tough
Aug 14, 2010 | Computers & Internet
My laptop dv6000 the screen doesnt work so i
does it display on external monitor, if yes then do not worry just change the balesh of the screen of ur laptop it does not cost more,, for more view www.ecwnepal.com
Jul 06, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Display on HP DV6000 is scrambled.
Your problem is the screen itself, sounds like your graphics chip is fine by being able to use an external monitor. Change out the display, but also check the flat data cable on the back of the screen and make sure it just didn't slip out of the socket.
Oct 14, 2009 | HP Pavilion dv6000z Notebook
Hp special editon dv6000 display wont load.
Not sure if this is whats up with your laptop but there is a recall on the dv6000. The following link has more details on whether your laptop is one of those affected.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c01087277&product=1842155
Mar 19, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 Black Screen!
have you tried an external screen? did the same happen there
Mar 12, 2009 | HP Pavilion dv6000z Notebook
Plz help my laptop has no display dv6000
More info please. Does it show a boot screen first then go blank? Does it beep when you turn it on? Has your display flickered recently or have the colors shifted?
Jan 04, 2009 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
159 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
