Question about Cameras
Bebob zoe 111, remote zoom 8- pin configuration
  • 3,083 Answers
Looking on the net didn't provide anything useful- was hoping for a user site on which someone might be able to provide some help.
Unless you can find someone that has the service manual/schematic for this, it's going to be hard to find the pin configuration. I would suggest contacting Bebob's support site, and seeing if they could supply the information you need. Here's their contact site:
http://www.bebob.de/?lang=en
Good luck, and hope this helps.
Posted on Oct 04, 2010
I need an 8 digit pin number for my wpn824 wireless router. I am trying to set up Web disk. There is no 8 digit pin number on the router or the packaging.
the 8 digit pin is usually located on the sticker under the router. it is labeled as security pin. or anything that is related to that phrase.
Aug 25, 2011 | NetGear WPN824 108Mpbs Wireless Router _...
Hello I was wondering how to use the VM acess with my phone. I want to be able to call from a different number and listen to my messages how do I go about doing so
I have a similar model. You need to configure a remote access code on the phone. Then, when you call your phone, you enter the pin after your message starts.
(From the manual)
Using a touch-tone phone, you can call your phone number from outside and access the unit to listen to messages or change answering system settings. The unit's voice guidance prompts you to press certain dial keys to perform different operations.
Remote access code:
A 3-digit remote access code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. The default
setting is "111".
Important:
To prevent unauthorized access to this product, we recommend that you regularly change the remote code.
1 {MENU} {#} {3} {0} {6}
2 Enter the desired 3-digit remote
access code.
3 {SAVE} {OFF}
Below is a link to the manual. The remote access instructions are on page 35.
http://static.highspeedbackbone.net/pdf/KXTG4031-MUL.pdf
Mar 05, 2011 | Panasonic KX TG4031 Cordless Phone
Front panel 10 pair motherboard plug in configuration
this will do
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Jan 15, 2011 | AOpen AX45-4D Max Motherboard
Wharfedale 21in tv blue screen with the word key in top corner with 3 dashes please help
You have accidentally activated the system lock or parental lock. This usually happens when 2 buttons are pressed on the remote simultaneously.
You will need to enter a PIN number using the numerical keys on your remote. If you have set a PIN number for this TV you will need to enter this. If not, you will need to enter the manufacturer's default PIN number. This is usually a simple combination such as 000, 111, 222, 123, etc,
I can't tell you the exact PIN number without knowing the model number of the TV. Please try the simple number combinations shown above and post back with the model number if you need further assistance. The model number can usually be found on a sticker on the rear of the TV.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
Zoom 9030 works well after all these years there is a memory battery that needs to be changed every 5 years or so. The only problem is when I plug in the 8050 foot controller it won't change any patches...
It is LIKELY that one or more pins and or wires in the remote cable are broken.
These MINI DIN connectors are "tender" and are easily broken and wires flex at the back of the connector and are broken.
FIRST check that all pins are present at BOTH ENDS of the cable.
NEXT use an ohmmeter to check continuity of each and every pin end-to-end. I suspect you will find one or more broken.
Be aware that repairing this cable requires patience and steady hand as the pins are so close together it is easy to have solder bridges, etc. Sometimes just opening the connectors are a problem to access the pins. Sometimes the cables are MOLDED and those are UNREPAIRABLE other than cutting off the bad conector and replacing it. You can usually buy replacement connectors at DIGIKEY.com and or Mouser.com. You have to CAREFULLY select the apporpriate pin configuration from the catalog page. One needs a small soldering iron and magnifying glass to work on the cable.
USUALLY the wires go from pin to pin. Also a shield on the cable has to be dressed and connected usually. You may find the shell of the connector tied to a pin or just the sheild of the cable.
Jan 08, 2010 | Zoom Music
Device asks for passphrase or pin, what is this,(zoom 3g router)
The passphrase is used to generate the encryption code in the router's wireless configuration.
For instructions to configure the router's wireless settings ant to configure the wireless card in the laptop/computer - please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 03, 2010 | Zoom Computers & Internet
I have a zoom 8050 foot controller buy have lost the data cable (8 pin). can you help me find one, or suggest a replacement cable? zoom/samson were not helpful at all. thanks. mic
I could not find a manual online to check on cable type, however if the cable has the little plastic connectors similar to the telephone jack type but are 8 pin, then just get a standard 8 pin Ethernet cable at a local computer store. Some pedal boards use these.
Another option ios to get connectors and make your own.
Aug 31, 2009 | Zoom Music
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
