Question about Fuji Cameras
Im trying to use the memory card but the camera says its full... I deleted everything and used a brand new card but it says the same thing. I even tryed formatting the camera..
  • 57 Answers
Is it telling you the the card specifically is full or just full. Some cameras need to be switched from onboard memory to memory card. Also, if you are using a high capacity memory card make sure your camera can take a hgih memory card. If you put a 2 or 4 gb card in and it says full that means your camera can't use those cards.
Posted on May 27, 2008
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
Feb 27, 2013 | Kodak EasyShare Z710 Digital Camera
My phone keeps telling me I have low internal phone staore even after I deleted everything. What do I do
If it is a Nokia, try deleting files from Phone's memory (not from the Memory Card).
Nokia has a (should I say) a nasty habit of popping pretty annoying messages about space.
Default settings for the Camera and Bluetooth allow the things to be stored in the Phone's Memory instead of Memory Card which causes this problem.
Check the memory status of your phone if Phone's Memory is about full, there is your problem just delete everything you find useless.
If you are not using a Nokia try the same and if it still doesn't work please specify the Brand and Model of your phone. :)
May 26, 2011 | Cell Phones
When i try to use my camera on my phone it says that my memory is full even though its empty.
To resolve this problem:-Turn off the camera and insert a new memory card.
-Transfer or delete pictures from the memory card.
-Change the storage location to use the internal memory.
Apr 21, 2011 | Cameras
Memory card is always full even though it is new
Hi, The solution is to format the memory card or initialize the memory card. Note formatting the memory card will delete all the pictures or data stored. Formatting memory card
1. Press the MENU button in any mode.
2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu.
3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
Apr 12, 2010 | DXG Technology DXG-409 Digital Camera
Wont accept a new 2GB memory card, its saying memory full.
Unfortunately, this camera will only accept up to a maximum of 1GB for a memory card.
So you will need to use a smaller memory card.
It's not in the documentation, but it should be.
May 02, 2009 | Kodak EasyShare C330 Digital Camera
Kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
Jan 18, 2009 | Kodak EasyShare C330 Digital Camera
I accidently deleted the fuji folder thats inside the dcmi folder on my external memory and now i cant get the external memory to work or even a new memory card. Help
after several hours of trying to get answers through you and calling e mailing... everything with absolutly no help whatsoever. No one understood what i was saying. I kept turning off the camera and then trying everything again. I even used a different card and still nothing it still said memory was full when there was nothing on it. So what i did was i took a few pictures without the external memory.. so it used the internal memory then i reviewed them so i seen that worked. After i did that i re inserted the memory chip and it must have reset itself because all of a sudden it worked. I figured it out myslef.. so much for technical support.
Jul 04, 2008 | Fuji Cameras
MEMORY FULL ?? CD310CE
if your cam is using a sd card, the card could be locked, theres a little switch on the side of the card try using that and see wat happens. its tiny on one of the sides.
Jul 01, 2008 | Cameras
Message Display
sometimes this problem occures due to defective or fake memory media. try using a good branded card.
Sep 09, 2006 | Panasonic Lumix DMC-FZ10 Digital Camera
Cameras Logo
595 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
