Question about Lexmark X125 All-In-One InkJet Printer
Refilled cartridge does not work
I refilled the Lexmark x125 black inK cartridge at Walgreens. When I put the cartridge back in the printer, the machine will not copy or print from the computer. I get the message "add right cartridge". I have tried taking it out and putting it back in. That did not solve the problem.
Thanks fo ryour help with this problem.
  • Anonymous Aug 14, 2008
    I put in new cartridges (black and color) still get: Add right cart.
    only color prints. Thanks for Help. Grandma
  • 23 Answers
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
Posted on Jun 20, 2008
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
I've refilled my black ink cartridge #36 and put it into my Lexmark 5650. My computer will not let me print - not even to "complete a page" print. It says that I need more ink. I have windows vistas. What...
Lexmark 36 and 37 cartridges cannot be refilled. When your ink levels drop below a certain point your printer deactivates the electronics on your cartridge so you cannot refill them. I own a Cartridge World ink refilling shop and I sell Lexmark originals for the 36 and 37 because of this reason. Unfortunately you purchased a machine that you have to buy expensive original ink for. You need to buy Lexmark original 36 and 37 to get your printer to work. As a refiller I never recommend someone buy a Lexmark printer if they ever want to use refills.
Jan 20, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
Refilled ink cartridges at Walgreens, printer won't recognize
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Aug 05, 2009 | Lexmark X2550 All-In-One Printer
I cannot get my printer to recognize my refilled ink cartridges
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 20, 2009 | Lexmark X2500 All-In-One Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
Refilled cartridges not working!
Lexmark Printers doesnt support refill catridges thats the Problem............
Jan 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
How to remove the ink cartridge from printer
gently pull the front panel towards you. then lift the back panel (towards the wall). your cartridges will come forward. gently pull them towards you to unclick then from the holders. there should be directions on the inside of the back panel on how to install/replace them. Hope this helps.
Nov 18, 2008 | Lexmark X125 All-In-One InkJet Printer
need to install the printer on to my lap
Oct 19, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
341 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
