Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pny usb 2.0 flash drive memory stick
How do you connect this up to an ordinary computer the instructions just say plug the flash drive into the usb port of the computer but the end dosent fit??
  • Anonymous May 29, 2008
    how to copy from internet
  • Anonymous Mar 12, 2014
    pny attache hook 16gb usb flash drive
THIS IS LOW DREIVE HE IS IMPORTED PRODUCT
Posted on Jun 07, 2008
Windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
Posted on May 28, 2008
Not detect pny 2 gb pendrive in desktop & laptop
You should try and blow into the usb end of the memory stick, and also into the Port on the computer where the usb stick goes in. This most often helps. If not, you may need to write to the makers of the stick, and complain. They will most often replace it for you, if you have had it less than a year and a half.
Hope this helps,
Pennywise25
Jul 14, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Down load pictures from computor to pny 4gb usb 2.0 flash drive
U NEED TO FORMAT IT 1ST INSERT THE FLASH DRIVE GO TO MY COMPUTER GO TO THAT DRIVE IT MYT B NAMED AS STORAGE (E) OR (F) DAN RIGHT CLICK ON IT SCROLL DOWN TO PROPERTIES CHOOSE FORMAT AND SELECT QUICK FORMAT. HOPE THIS IS HELPFULLY. :)
Apr 15, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to use pny memory stick
Put it into a spare usb slot and it should install. You can then find it in' My computer' as a removable drive. Double click it and drag whatever files you wish into the resulting window.
Jan 13, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY flash drive
Plug it into your USB port on the computer, works like a mini hard drive sort of. When you plug it in, it should ask what you want to do, see files etc. Just drag and drop files in or out.
Dec 04, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
IS there a driver for the PNY 4gb USB 2.0 black (and red) memory stick?
Hi
USB memory sticks do not need a driver, it comes with windows, unless you have a really old pc with windows 98 or similiar.
Oct 12, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have lots of photos on my computer. I don't
plug it in. it will auto detect and you will be able to drag and drop
Jun 09, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a pny 4gb usb 2.0 flash drive black.instructions needed.
Most USB drives are "plug n play" meaning you just plug it in to a USB 2 port and your operating system will recognize it as a drive. If you're using Windows ME/XP/Vista, just plug it into a USB 2 port and once its recognized you'll be able to send files and folders directly to it by right clicking the file or folder and moving your mouse over SEND TO and selecting the drive from the list.
Nov 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pny memory stick
once it is erased of your pen drive it is erased for ever
(you dont want to format it it will erase your date)
hope this helps :-)
Aug 31, 2008 | Electronics - Others
Pny 4GB
for connecting the dongle open the cap
connect to the USB port u had infront or back
wait for some time for recognisation the dongle stick
after finishing ur work do not plug it out
select the stick and right click on it
select the "Safely remove"
wait for some time till u get message as "Its safe to remove"
then only un-plug the stick
Let me know if your problem is solved and rate me as FIXYA!
May 24, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
211 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
