Question about Sport & Outdoor - Others
Need replacement hangers please. Where can I obtain?
    Problem Solver:
  • 15 Answers
Are we talking Bicycle rear derailuer hangers ?
we sell them, but there are over 130 different ones, will need to know what brand, model & year.
Posted on Oct 04, 2010
I have a 1988 cadillac elderado and my keys are in the trunk... My car doors are locked as well. How can I get them out without calling a lock Smith?
Does your car door locks have small lift up knobs on interior doors? You would push down to our ck car. If you do then get a metal coat hanger and small wood wedge.
then untwist coat hanger end create a loop on end so you think it would slide around door lock.
gently pull top of door away from body and of car see if you can put wedge in to hold door slightly. The goal is to insert coat hanger down so you can maneuver over lock, once you do pull up.
you should bend coat hanger thinking of how you will slide into car and long enough to turn and twist until you unlock.
metal coat hangers can be obtained at a dry cleaners.
Sep 30, 2016 | 1988 Cadillac Eldorado
How do I mount a 32" Wrought iron pendulum wall clock?
studs r on 16" centers (usually).
hanger needs to be secure in a stud and sized for clock weight.
hanger arrangement depends on clock config
plan on removing clock from wall to replace batteries.
Sep 21, 2014 | Sterling & Noble 20 Wrought Iron Wall...
Will this derealler hanger fit my Colnago Ace 2013
Jose , It looks close if not perfect. The best way to find out is to install it and test it. I would just check the widths of the replacement before that though..
Mar 19, 2014 | Colnago Mech Hanger | Suits...
Install foot rest
If you have the swing on footrests or legrests for a Pride Jazzy series with 2-pins on the hanger brackets please be sure that the hanger brackets are properly installed on the chair with the pin side of the bracket facing to the outside - not inside. To put the footrests on - align the lower pin first with the footrest at a 45 degree angle to the outside of the chair. Then align up the top pin and lower the footrest onto the hanger bracket. Rotate the footrest towards the front and lock the cam lock in place. If the cam lock has a handle that is bent it will interfere with the lock and need to be replaced or bent back in place.
Nov 13, 2013 | Pride Jazzy 1113 Power Chair
Need muffler bracket
If the hanger is still there you just need to put it back in the hanger. If it is missing head to a parts store. they can tell you what hanger is missing and sell you a replacement. Easy to install.
Oct 06, 2012 | 1999 Jeep Grand Cherokee
How to replace a hanger bearing on a G20 CHEVY VAN
It is pressed in in, but most just replace the entire center support assembly it is allot easier.
Jun 27, 2012 | Cars & Trucks
I have a nv30 infinity vacuum. The handle is clogged with a sock right where the flexible hose begins. I cannot reach the sock even after removing the telescoping tube. How can I unclog the handle?
Hi Jackie ma268...
You need a metal coat hanger nd a pair of pliers.
You will straighten out the coat hanger with a pair of pliers, except the end that you hang the clothes hanger up with, because it has got the hook already made..
After you have gotten the hanger straight, you will take the hook of the hanger and make a smaller hook that will slide easy into your hose with the hook being able to catch the sock ...once it has caught the sock, then twist it a few times so that it will get caught up in the sock really well...then pull the sock out of the hose...Job done.
Please take time to rate me
Sep 06, 2011 | Vacuums
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jul 09, 2011 | Cycling
My turn signals don't flash
make sure all the bulbs are working. If not check the fuse but i doubt its a fuse cause none of the lights would be on but check the flasher. Flasher Location
It is located under the dash board on the drivers side. You will need a flash light, zip cord for re-installation, a long non metallic rod 1/4" dia and a wire hanger. Bend hanger straight and make a little hook on end. Remove turn signal fuse located at fuse box under driver side dash. Lay on floor with flashlight on drivers side. Look above fuse box it is located above it about 10" it is round and silver. Use rod to push off clamp. Now use hanger to retrieve flasher unclasp and install new flasher. Reinstall flasher and clip under dash with zip cord for access later. Replace fuse. If you need further assistance please let me know. Thanks, midwest-tek
Sep 17, 2010 | 1992 Buick LeSabre
1995 Jeep YJ Exhaust / Muffler / Cat Conv on Hangers
use a jack to force the muffler into position, or you may have to move the hANGERS accordingly
Mar 29, 2009 | 1995 Jeep Wrangler
Sport & Outdoor - Others Logo
46 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
