I loaded my 2gig memory card with music and when I put it into my phone I could not find my music when I put the card onto another phone it played the music so am stuck now
  • 11,800 Answers
In some phones each type of file must be put in a specific folder.
Format the card in the pc and leave it blank. Put the card in the phone and format it there also - this way the specific folders will be written in the card. Take the card out, put it back in the pc and find the Music or Sounds folder - put the music files directly in it.
Posted on Oct 04, 2010
SOURCE:
Memory card. !! please help );
Don't know much about the Samsung phone; Can you put music on the 1 Gb memory card from another source (like a computer) and have it recognized by the phone?
Does the phone require music in a particular format? For example, if the phone recognizes .mp3 music files, but all your music is in Ogg Vorbis (.ogg) files, you will not be able to play them on the phone.
1) Find the Samsung phone manual (online?) and see if it requires music files to be in one format, or another.
2) Try loading music, in the proper format, from different sources onto your memory card.
Best of luck!
Nov 12, 2011 | Samsung Cell Phones
I cannot transfer music from micro sd to my kyocera phone
You should not need to transfer the music from the sd card to the phones memory, but play the songs directly from the sd card. Once the songs are loaded onto the sc card in the right format, (MP3) your phone should find them on the card.
Feb 23, 2011 | SanDisk Electronics - Others
I just put music on my card but i dont know how to load it onto my phone. can someone help?
First you need to make sure that the music files that you put on the card are compatible with your phone. You have to tell the phone where to look for the music files. Access the menu on your phone, and look for "memory." You have some limited memory on your phone itself, but you want to access the memory card. You can also set your phone to "save to" the memory card as well for videos, etc., this way you won't fill up your phones memory, and it is easy to transfer you files between your phone and other devices, computer, etc. My phone for example will play only the files on my phone by default, until I set it to play files from the memory card. You need to learn more about your particular phone, not so much the memory card itself. Please rate appropriately and leave a response. I hope this helps and good luck.
Oct 23, 2009 | PNY 2GB microSD Memory Card
Memory card isnt recgognised!
If the card is inserted correctly and its not damaged, then the memory card should show up under media manager, you need to put the files onto the memory card not on the phone...
When you first insert the card into the phone, you need to format the card, some phones create specific folders for different things when they format, e,g images, Videos, etc. You may need to do this.
I cant remember if this phone had this option but try it anyway as if it works, it should be faster than using Samsung PC Studio...
Close Samsung PC Studio
Unplug USB out of the Phone and a couple of seconds later plug it back in, see if the phone asks you for Mass Storage mode... If it does select that, after a while the Memory Card should show up on your PC just like a USB memory stick you can drag and drop files to it and its faster than going through Samsung PC Studio :)
May 09, 2009 | Samsung C417 Cellular Phone
Ks360 mobile phone 2g memory card not workin in phone.
You need to copy all your files from your memory card onto your pc, then format the memory card in the phone using them menu. Then copy all of your files back into the correct folders that the phone has created on your memory card.
Mar 30, 2009 | Cell Phones
MicroSD does not contain supported music files
I went back to the US Cellular store and presented the problem to the salesman that sold me the phone. He said that I needed to remove the memory card and put it in a card reader and transfer the music files to the card through the card reader. My Gateway desktop has a card reader and I transferred the music files to the card and then to My Music folder under My computer and it worked. Strange to have to do it this way but it works.
Dec 21, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Music isn't transferring onto my memory card,please advise
When buying a memory card the first mistake I made was putting my files onto the memory card first. Try putting your memory card into your phone and go to Format Memory Card, this will erase all the files on the memory card but it will make it so your phone can read the files
I hope this will fix your problem T. Shanks
Dec 20, 2008 | Nokia 6220 classic Smartphone
Down loading music and pictures
just get the software from the internet and the usb cable, or if u hav a memory card on usb mode (in phone settings) go on mass storage, and connect ur usb and it shud work if dat dunt work get a memory card adapter and conect it 2 ur laptop and send it 2 it hope this helps.
Sep 16, 2008 | Samsung SGH-D900 Cellular Phone
I have the cect p168c and I downloaded music for computer to my sd card but it wont play on my mp3 player on phone can you help
cect p168c won't play mp3 music that has been loaded onto SD Card. Shows to be in the phone under file manager my music. When you try to play it. Shows to be an empty play list.
Aug 03, 2008 | Cell Phones
LOADING MUSIC OFF CP TO PHONE USB CABLE
Hello Igvnos, what phone do you have?
Perhaps you'll need to change the setting on your unit to connect to your memory card.
I'll be able to help you better once I know what model phone you have.
cHiPz.
Mar 19, 2008 | Motorola Mobility RAZR V3
Open Questions:
Computers & Internet Logo
56 people viewed this question
Alun Cox
