Question about Ovens
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
    President:
  • 1,138 Answers
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Posted on Oct 04, 2010
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Dont know how to turn off the auto seting
Turn off the mains power. wait about thirty secs. turn back on, you should have either all 0's or 8's flashing. Looking at the clock buttons left to right. press the button fourth from left and the - or + to set the time (doesn't have to be the correct time, just not flashing 0 or 8's). Leave for second until the display is not flashing.You should be able to use the oven now. If not you may have a problem with the clock, this can happen if you have been using the top grill with the door open and the controls have gotten too hot. Neff ovens have no function where the door is left open during cooking or grilling.
Mar 07, 2013 | Neff U1721 Double circotherm Electric Oven
Neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
Please advise how to reset the time clock on a
Hold down 2 buttons - the first button on lhs "timer bell" the "hand" button and then use plus and minus with the other hand to set the time.
Jan 07, 2010 | Neff U1721 Double circotherm Electric Oven
Can't adjust the clock on my 1442 Double Oven
Press the left button 4 times, this takes you to the time which is now flashing and can be changed with the right button. once set, leave it and it will just work from there (i.e stop flashing etc)
Apr 01, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Neff B1641 Switched my oven on the other night it made a noise like a fuse blowing and went dead no lights no controls whatsoever i checked the power and i traced it all the way to the control panel...
check you have power at the clock - the clock terminals not the relay. if not, there is a cut-out stat in the back. check this is still ok. if there is power at the clock then the clock itself may be faulty. you can bypass the clock by joining the terminals to the clock relay and get the oven going this way. another common source of problems is the terminal block where mains comes in and is distributed. these terminal blocks often burn out.
May 04, 2007 | Neff B1641 Single circotherm super...
Ovens Logo
443 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
