Question about HP LASERJET P1005 Printer
Hp laser jet p1005 engine fuser error - HP LASERJET P1005 Printer
Cops
  • 64 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
  • 125 Answers
The fuser bonds the ink powders onto the paper. It is usually located behind the cartridge in the paper path. There may be several reasons why this error shows. (Bad fuser or bad power supply). It looks like this:
http://printerworks.com/Catalogs/hp-supplies/Q3655A-CLJ-3500-3700-supplies.htm
Here is some useful info:
http://www.fixyourownprinter.com/forums/laser/42184
http://www.coldreset.com/modules.php?name=News&file=article&sid=200
Posted on May 12, 2008
Maanita
  • 1142 Answers
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Posted on Aug 17, 2008
SOURCE: HP Laser Jet 2840 50.2 Fuser Error
Usually this means that the fuser is not heating to the correct operating temperature. Remove the fuser and check all contacts. Be careful it can be very hot. Always let it cool down for atleast 30 minutes before touching the face of the fuser. After you check it over and clean off any contacts, reseat the fuser back into the printer. Plug it back in and turn the printer on. If this doesn't work and you still get the error, the fuser needs to be replaced.
Posted on Oct 09, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
Printe shows out of memory HP LASER JET P1005
If its refilled cartridge, replace with new one & check, even its showing same error check cartridge memory contact unit located under the cartridge bank...Most of the cases we observed memory reader unit breakages happening. while inserting the cartridge it has to move to contact memory.. if its not moving properly results no contact between memory and memory reader.
Jul 20, 2012 | HP LASERJET P1005 Printer
I have my hp laserjet p1005 it has an error fuser engine how can i solve
Don,t entertain fuser repair, just replace it with new one..
Oct 27, 2011 | HP LASERJET P1005 Printer
Engine fuser error
The fuser unit may not be seated or inserted properly.
Try removing the fuser unit and insert it back into the printer. Make sure the two spring contacts in the fuser unit are seated firmly.
Mar 12, 2011 | HP LASERJET P1005 Printer
How to solve Firmware Download error on P1005
when i try to print by hp laser jet p1005 the red led is flashing then error appear (firmware download error) the printer was unable to communicate with your computer
what can i do to solve this problem
Mar 08, 2011 | HP Hewlett Packard LaserJet P1005 Printer
Hp laserjet printer p1007 engine scaneer error
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Dec 09, 2010 | HP LASERJET P1005 Printer
My HP laser jet P1005 cannot install with ACER Aspire windows 7 system but can install with another pc Vista system. why ? please help me, thanks
To instal HP Laserjet P1005 Printer on you Aspire System with Windows 7, you need to install Windows 7 drivers for HP P1005. Click here to go to HP Official and download Windows 7 Drivers for HP P1005. Select the Operating System (e.g. Windows 7 32-Bit)
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | HP LASERJET P1005 Printer
Erro no fusor da hp laser jet p1005
it seems to me that the fuser is blown, and needs to be replaced, but to repair this requires a dissaembly of the fuser, its the themister and the element that is blown.
not worth it, replace it.
Nov 12, 2010 | HP LASERJET P1005 Printer
I run the hp laser jet p1005 setup cd on windows xp 2006. It goes well until it asks to connect the printer and power on.I did that.Then the hardware wizard identified the printer and displayed "you...
Ok,right click on my computer > manage >divice manager >just check for yellow or red cross button and right click on that say update driver it will give you a wizzard go thruogh it, if it red cross just click on enable
Sep 16, 2009 | HP LASERJET P1005 Printer
HP LASERJET P1005 Printer Logo
567 people viewed this question
Seeker5211
Seeker5211
