Question about Sennheiser HDR 120 Consumer Headphones
Audio cuts out after a few minutes. I have turned up the volume on the source but it makes no difference. Have changed product at store but the new set behaves the same way. Useless. Very disappointed with this product.
  • des_mueller Oct 04, 2010
    Range is about three metres. Batteries fine. After about three minutes the green light on the transmitter goes out.
    audio cuts out after three minutes even with volume on source turned up
    President:
  • 2,047 Answers
Headphones are such that it is very unlikely for 2 sets to have the same problem. If the first set has been replaced and the new set behaves the same way then there is a high probability that the problem is not from the head phones but from the device which it is plugged to.
Test the headphones on a different device and get back to me if the problem persists.
Hope this solution has been helpful?
Posted on Oct 04, 2010
  • 2,069 Answers
Have you thought of the source compatibility or even the range? your headset operates well with Range of up to 100 metres. audio largely depends on the source. and this being a wireless RF headphone system, interference would also play part. so kindly check all those. otherwise, that model has Good quality sound and Battery life is good
  • Muzahura Frank Oct 04, 2010
    what is your transmitter model
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
    It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
    U.S., Canada, & Puerto Rico - 1-800-305-2204
    Mexico - 1-888-882-7326
    daily from 7 am - 12 am CT.
    Sep 04, 2013 | Dynex Televison & Video
    Arcam AVR200. Buzzing sounds in all 5.1 speakers. Gets louder as volume is turned up. Tried all sorts of different things - different power source, 1 speaker, different modes.
    I had the same problem. I was told by a sales guy at a high end audio store that I should try using a 3-Prong To 2-Prong Adapter. I went and bought one. I plugged it in and no more buzzing.
    you can find them at HomeDepot, Lowes or dollor store.11_25_2012_6_28_23_pm.jpg
    Jul 12, 2011 | Arcam AVR-200 Receiver
    Output will cut out -- headphones work for a bit then they too cut out. Turn it off and don't touch the volume control. When you turn it back on it might work for a few minutes or it might not.
    This is an indicatin of a circuit overload condition and is being handled appropriately by the protective circuit built into the output side of the amplifier. Have the problem fixed by an electronics shop to avoid blowing out or burning up your speakers and headphones. One thing to check at home is to make sure there are no shorted wires to the speakers you are currently using. Try different wires and a different set of headphones.
    Hope this helps.
    Feb 10, 2011 | Denon AVR-2802
    Volume cuts out, volume knob overloads when touched
    If this is the old style potentiometer unplug amp and remove cover to get to volume control. spray contact cleaner made for that purpose at the radio shack stores or similar. Spray it into the control and turn the control back and forth to work it in. Let stand for a few minutes and try it again. Always make sure it is dry on all components first.
    Jun 07, 2010 | Pioneer Audio Players & Recorders
    Sound
    Hey merrybell;
    So, you have a flat panel with no sound?
    Well, with out Brand or Model let me start here:
    1. Unplug 'flat panel',cable box or sat. box from the power source, a/c cord from wall, for at least 4-5 minutes, plug back into wall.
    2. Make sure volume level on TV and boxes are turned up, some cable boxes have volume controls.
    3. Ensure that speakers are turned on, some 'flat panel's' have options of turning speakers off. Check menu....audio/sound.
    4. Double check all cables from 'flat panel' to "boxes", make sure they are secure.
    5. Try different inputs and devices (dvd) on 'flat panel' or cables.
    6. If still no audio, one the boards may be defective.
    If so make sure you call a factory authorized service dealer to service your 'flat panel.
    Good Luck, Big Irish, get back if have any more info.
    Jun 20, 2008 | Televison & Video
    RCA Wireless headphone triggers off after 35 seconds of operation
    ya the volume of your source is your issue.
    if it is too low, the unit cuts out after 45 seconds or so...
    crank up the volume and turn it down on your headset
    Mar 16, 2008 | RCA WHP140 Consumer Headphones
    Alpine CDA-9857 Volume Fluctuations
    Please see my solution posted on Mar 13. No other brain waves yet!
    Mar 13, 2008 | Alpine CDA-9857 CD Player
    Volume is changing/decreasing
    well, that information is slightly undescriptive and unnecessarily vague, but I think I can suggest a few things.
    If the problem only occurs when watching your HDTV, I am assuming you are using the Audio Out on your TV to pipe sound down to your Onkyo receiver. If this is the case, the TV volume may be turned down lower by mistake and you have to turn up the Onkyo's volume to correct for the difference.
    Another possibility is that some other variable has changed i.e. source material, programming, TV firmware update. What did you change to get this to happen? Is it reproducible? Can you use other source material (DVD, VCR, or DAP (mp3 player) and use it at the same volume levels as before? I tend to think that your problem is with the HDTV, not the Onkyo. User error is the most common type.
    Jan 14, 2008 | Onkyo TX-SR503 Receiver
    Sennheiser HDR 120 Consumer Headphones Logo
    228 people viewed this question
    Top Sennheiser Audio Players & Recorders Experts
    Michial Gueffroy
    Vito Vacirca Jr.
    Rob Beech
    Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
