I am having problems taking photo's at night. This is due to the fact when it is dark I am unable to see on the screen what I am Taking!! With previous cameras it illuminates what I am about to shoot so this hasn't been a problem, doe this camera not do this? The flash works but due to the fact I can't see it is pot luck whether I have a photo of what I was hoping to aim at!! Your assistance wou.ld be appreciated
Did you accidentally switch the the camera to manual mode or to night shots. (night portrait) in scene?
Just chose the little camera logo on the mode dial and try again. If you still have problems I hope to hear from you.
Hi, Your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. If the problem is due to your dropping the camera, you might be out of luck. If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hi, Your camera is having horizontal lines due to a faulty CCD, and not due to other problems. Just tap on the side of the camera at times the horizontal lines will disappear. If the problem is due to your dropping the camera, you might be out of luck. If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
no there isn,t.but these cameras do not have enough flash to take great pictures at night,for one you cant be to far away,two you have to have a subject in range of the flash,other wise all you get is darkness.but at the most 10ft is the farthest you can go and still get a great shot at dark.also use auto mode when taking pictures,because it adjusts to light-dark etc.i know this because i have the same camera and its awesome,plus im a photo technician and ran a photo lab for 3years selling digital cameras. good luck,hope i helped
my friend ur CCD is getting weak this is the first sign of the problem when u get lines hor and vertcal and sun light pics are blurred and over exposed after that this problem extends to the indoor shots as well pls confirm it thru service centre for 100% ,
pls do rate me i know it is a difficult moment but i helped u in diagnosing ur problem without wasting time
this problem may happen due to sticky shutters. when a camera is left non operative for a long time sometimes the the shutter gets stuck due to some sticks substance between the blades. BUT you specified thet it's not taking OUTDOOR PICTURES that means that it is working fine indoors ??? That's confusing..
Hello, When taking photos in low light or night time,turn the rotary dial that you use to turn on the camera all the way to the right as far as it will turn.the symbol looks like torso of person with a star above it. this is the night setting,exposure time is increased so you may have to rest camera on solid object to prevent blur.This should do the trick. Best Regards,Russell
anyone else had this? or know what to do.
whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
