Question about Cycling
We want some informations about keys on the computer keyboard..................
    Problem Solver:
  • 15 Answers
You are in bicycle ?'s
To get answers you will need to give make & model of problem peice.
Posted on Oct 04, 2010
Needtogetaroundcomputerkey
You can adjust turn on or adjust settings for these features on the Use the computer without the mouse or keyboard page in the Ease of Access Center. Open the Use the computer without a mouse or keyboard page by clicking the Start button , clicking Control Panel, clicking Ease of Access, clicking Ease of Access Center, and then clicking Use the computer without a mouse or keyboard.
Select the options that you want to use:
Use On-Screen Keyboard. This option sets On-Screen Keyboard to run when you log on to Windows. On-Screen Keyboard displays a visual keyboard with all the standard keys. You can select keys using the mouse or another pointing device, or you can use keys on the standard keyboard. For more information about using On-Screen Keyboard, see Type without using the keyboard (On-Screen Keyboard).
Use Speech Recognition. The option allows you to control the computer with your voice. With a microphone, you can speak commands that the computer will understand and respond to, as well as dictate text.
May 11, 2015 | Computers & Internet
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
My Dell XPS L502 laptop keyboard locks up?
Instructions
Buy a can of compressed air and spray it on the keyboard if your keys are sticking together. This is the easiest thing you can do to fix the keys on your keyboard. It doesn't work for all problems, but it's a good place to start. Make sure you get the air down inside the keys to clean out any debris, hair or food that may have gotten caught in there.
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Wal-Mart or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
3Use a small dab of super glue to replace keys that have fallen off. Dell laptops often have keys that fall off, especially as the computer ages or is used quite frequently. Place a small dab of glue directly on the round part that holds the key in place and lightly press the key down. When the glue dries, you'll be able to use your laptop again.
Remove any problem keys from your keyboard and look at the plastic retainers. At times these retainers can become broken, damaged or simply fall off. Carefully pull off the retainer, clean it off with some compressed air and snap it back into place. Then put the key back into the slot and everything should work fine.
5
Consult the Dell manuals website to get information on your specific laptop computer. The manual will include information on troubleshooting and repairing any problems with your laptop. If you find that none of their suggestions work, you can also use the website to find the customer service number. You'll need to call the number and ask for help or advice.
Jan 10, 2013 | Dell XPS 15z XPS15z72ELS PC Notebook
How to system unlock a gateway desktop computer
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual.
hope this helps
Jul 23, 2012 | Gateway Computers & Internet
My sister has a Dell Latitude CPxJ650GT computer with a Dell Keyboard. She is unable to use the keys 67yuhjm on the keyboard. What can she do to repair this problem? Thank you for your kind...
  • Step 1
  • Step 2 Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Wal-Mart or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
  • Step 3 Use a small dab of super glue to replace keys that have fallen off. Dell laptops often have keys that fall off, especially as the computer ages or is used quite frequently. Place a small dab of glue directly on the round part that holds the key in place and lightly press the key down. When the glue dries, you'll be able to use your laptop again.
  • Step 4 Remove any problem keys from your keyboard and look at the plastic retainers. At times these retainers can become broken, damaged or simply fall off. Carefully pull off the retainer, clean it off with some compressed air and snap it back into place. Then put the key back into the slot and everything should work fine.
  • Step 5 Consult the Dell manuals website to get information on your specific laptop computer. The manual will include information on troubleshooting and repairing any problems with your laptop. If you find that none of their suggestions work, you can also use the website to find the customer servicemag-glass_10x10.gif number. You'll need to call the number and ask for help or advice.
  • Mar 07, 2010 | Dell 0Y3740 Keyboard
    Keyboard disabled. somehow disable my keyboard
    Did you try Fn+F5? You can usually disable the touchpad but keyboard?
    Try to uninstall the keyboard from device manager. Right-click on my computer->Properties->Device manager-Right-click on keyboard(HID keyboard device) and uninstall it. Then reboot your computer if you just disabled it windows will re-install the driver automatically and re-enable it
    Let me know if you need more help.
    Sai.
    Sai.
    Jan 29, 2010 | Dell Inspiron 1000 Notebook
    How to replace Dell Precision M6400 keyboard?
    http://support.dell.com/support/edocs/systems/wsm6400/en/sm/keyboard.htm#wp1179980
    Removing the Keyboard caution.gif CAUTION: Before working inside your computer, read the safety information that shipped with your computer. For additional safety best practices information, see the Regulatory Compliance Homepage on www.dell.com at: www.dell.com/regulatory_compliance.
    1. Follow the procedures in Before Working on Your Computer.
    2. Remove the LED cover (see Removing the LED Cover).
    3. Remove the four M2 x 3-mm screws along the top of the keyboard.
    notice.gif NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    1. Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
    Oct 01, 2009 | Dell Computers & Internet
    Keyboard doesnt type certain keys e.g. when pressing 'e' i will get My Computer pop up?
    This can be solved by reset:---
    1. Place the first CD, labeled CD 1, into the CD drive of your computer.
    2. Press the power button to turn on your computer.
    3. Hit the ESC key on your keyboard when you see the prompt at the bottom of your screen. (This will appear before your operating system begins to boot.)
    4. Hit the down arrow key on your keyboard to select “CD ROM.” This will allow you to boot from the CD that contains the factory settings for your computer.
    5. Hit "Enter."
    6. Follow the prompts by clicking "OK." Your computer will inform you that taking this action will erase all saved data on your computer. Click "OK."
    7. Insert the next CD-ROM into your computer when prompted. Continue to do this until your computer asks you to reboot.
    8. Hit CTRL+ALT+DEL to restart your computer. Follow the prompts provided by your operating-system setup program. At this point, you will be able to name your computer, register and set up your desktop.
    This will solve the problem. Thank you Sir, have a nice day.
    Aug 30, 2009 | Computers & Internet
    Keyboard
    No keys on my keyboard work. Cause: This issue is often caused by either a bad keyboard, bad interface board, and/or bad motherboard.
    Answer: Disconnect the keyboard from the computer and connect another known working keyboard to it. If this is a PS/2 keyboard and connecting multiple keyboards or a known working keyboard to the computer PS/2 port does not work unfortunately it's likely that the PS/2 port is bad. Because this port is part of the motherboard this will require that you replace the motherboard. Alternatively if replacing the motherboard is too costly or not an effective solution you could also consider using a USB keyboard if USB ports are available on the computer.
    Not all keys on keyboard work.
    Reference number: CH000305
    Not all keys on keyboard work. Issue: Not all keys on keyboard work.
    Cause: This issue is often caused by a bad keyboard or software preventing these keys to be pressed.
    Additional information: This document contains information about troubleshooting a keyboard that has some functioning keys. If no key on the keyboard is working see document CH000955.
    Solution: Verify that the key is not working in more than one application. It is possible that some keys may not be used in all programs. This generally always applies to the Function keys F1 through F12. If not all keys are working in all programs and you have Windows, attempt to boot the computer to a MS-DOS prompt or safe mode and test the keyboard in DOS. Information about getting into safe mode can be found on document CHSFAFE and information on how to boot to DOS can be found on document CHDOS. If it appears that a substance has been spilt into the computer, please review document CH000303. If all above suggestions have been completed or if you are not running Windows, it is likely that the keyboard and/or keys are bad and it is recommended that the keyboard be replaced with a new one.
    Read and follow instructions, Please dont for get to Vote/Thank You.
    Dec 28, 2007 | Computers & Internet
    Keyboard problem
    Information about computer keyboards Now with new technology, stuck keys are no longer an issue; ... Given all the above problems
    Information about the AT and PS/2 port 1, Keyboard Clock. 2, Keyboard Data. 3, Not Connected or Keyboard Reset
    Device Manager information and help Users who have a keyboard with a windows key may also quickly get to the system .... CODE 2 (Second Error)
    This should get ya back in to typing again/Good Luck.. Please dont for get to Vote, Thank You.
    Dec 19, 2007 | Acer Aspire 3680 Laptop
    Cycling Logo
    16 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you a Cycling Expert? Answer questions, earn points and help others
