Question about Microsoft Computers & Internet
IS IEX 9 INSTALL & FAST WORK IN WINDOW X
I have just installed internet explorer 9 beta and my yahoo msg will not work i uninstalled yahoo msg and now can't install it explorer 9 is stopping me and i can't find the uninstall for explorer 9 help...
Hint number one. Dumb IE9. Chrome is fast and it will work. 1. Press Control Alt Delete same time. 2. Choose task manager settings 3. Click on applications, if it says not responding end it. 4. If 3 doesnt work click on processes and end explorer 9.
Dec 20, 2010 | Yahoo Messenger
The scanner will not work, I have Vista 64 bit. Can't locate the disk that came with it now. Downloaded and installed drivers from HP site, still won't work. It says I need Windows 7 for it to...
1. If you have the disk then put the disk in and close the installation window that comes up automatically 2. Go to computer, right click on the disk icon that shows there and click on explore 3. Go to util>ccc and click on uninstall_L3 4. Restart your computer 5. Download the latest version of the adobe flash 10k (www.adobe.com) 6. Start installing once again and complete the installation 7. If the installation doesn't completes then let me know 8. If completes, try to scan, it should scan but if it doesn't then 9. Download the utility from the link given below and check where the error lies http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-86374-1&lc=en&dlc=en&cc=us&os=4063&product=3737195&sw_lang=
Oct 21, 2010 | HP Deskjet F340 All-In-One Printer
It will not work with windows 7. Is there
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all This should all be done in Administrator Mode. & done to BOTH the install .exe and the programs run .exe
Mar 05, 2010 | ScanSoft PaperPort Deluxe 9...
I cannot read the words
What version is the Adobe Acrobat Reader on your computer? If it is version 9 and you are trying to see the user guide from within a browser window (like Internet Explorer), you will have problems because of a known issue with Adobe Acrobat Reader2_bing.gif 9. If the above is true, you will need to uninstall Adobe Acrobat Reader 9 and install Adobe Acrobat Reader version 8.1.3
(Click Here) to download for version 8.1.3. If you are unsure how to uninstall version 9 and install version 8.1.3, please post a response to this an I will give you details based on your operating system.
Feb 08, 2010 | Microsoft Windows XP Professional for PC
Installed FSX & it worked fine yesterday. Tried to play it today & it says my graphics card doesn't meet minimum requirements. What gives?
Once you reboot or restart your system, FSX will run the checks that it didn't when you installed it hence the message. Upgrade your card and you will be okay. Suggest an Nvidia GTS250 if you want lighting fast graphics.
Jan 23, 2010 | Microsoft Flight Simulator X for Windows
I would like to scratch-install the new WINDOWS 7 on the TOSHIBA P105-S6114. Is this okay? Are there any problems I may encounter?
ecommended Windows 7 Installation Method SelectionToshiba provides support for installing Windows 7 on laptops built since 2007. Depending on your model, Toshiba recommends using one of the following software tools as part of the Windows 7 installation process, to support ongoing use of Toshiba provided features and functionality:
  • Toshiba Upgrade Assistant for Windows 7, for upgrading from Windows Vista to Windows 7 on laptops made in 2009
  • Toshiba Software Installer for Windows 7, for performing a Custom Installation of Windows 7 ("clean install") on laptops made 2007-2009
Find your laptop's serial number on a sticker on the bottom of the laptop, note the second character in that serial number, then click on the matching link in the list below for instructions on Toshiba's recommended Windows 7 installation method for your model.
For all laptops made since January 1, 2007*
When upgrading from Windows Vista (not a Custom or "clean" Install)
  • if the second character of your laptop's serial number is 7 or 8, click here.
  • if the second character of your laptop's serial number is 9, click here.
When upgrading from Windows XP, or doing a Custom Install ("clean install") from any operating system
  • if the second character of your laptop's serial number is 7, 8, or 9, click here.
  • if the second character of your laptop's serial number is not 7, 8, or 9 then it was manufactured prior to 2007.*
* Installation of Windows 7 is not supported by Toshiba for laptops made prior to 2007.
Hope it helped.
Nov 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Cannot complete uninstall of adobe acrobat 9 pro.
here is a link from adobe's website, this will help you completely remove the product.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb400654&sliceId=2
Apr 12, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Computers & Internet Logo
817 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
