Question about Kenmore 30 in.44062 / 44069 / 44064 Electric Cooktop
Kenmore Electric Counter Unit 43421
We have an older unit. Facing the unit, the right back burner is giving us problems. When you turn the dial to any number, 2-8, the burner heats up to maximum heat. My thought is that the Infinite Heat Control Part No. 320944 has gone bad and needs to be replaced. Looks like a simple procedure, just open everything up, pull the bad Heat Control and replace with new one. I would think the Infinite Heat Control is just a thermostat, and that is what the problem is. Any helpful thoughts that you can help with, I would appreciate it. Thanks. PS- We have switched burners, and control kobs, and the problem still exists when turning that burner on. Thanks for the help.
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
Posted on Jul 07, 2008
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
The right side back burner will not light. There is gas, I can smell it but the spark will not start. BUT, the spark will initiate and light the front right burner. What is going on? Its the same...
Can have below issue.
(1) Electric current is not reaching the ignitor. (wire is broken or have a leak)
OR
(2) Having problem with ignitor. (need to replace the ignitor)
Feb 03, 2011 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Unit on light stays on when unit is off
You need to check the switches. If no problems with the switches it is in the circuit for the indicator light. This is easy to check and the parts are inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru performing these checks.
Apr 10, 2010 | Kenmore 30 in. 42701 / 42702 / 42709...
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
Right front burner on high all the time.
Yes, the entire unit must be lifted out - it is probably secured with screws underneath. Then you can remove the screws on the underside of the glass to access the switch. Hope this helps!
Dec 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
All burners won't ignite when knob turn to LITE
how lite a eletric gas oven when power lite dont work
Jul 03, 2007 | Whirlpool GLT3014 Gas Cooktop
Kenmore 30 in.44062 / 44069 / 44064 Electric Cooktop Logo
182 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
