Question about Whirlpool GU2400XTPS Built-in Dishwasher
Need to know wattage of pump for insurance reasons
  • 901 Answers
You have to look at the pump label if any. Or contact the manufacturer.
Posted on Oct 04, 2010
How do I sort out insurance for my household goods and buildings after African independent canceled my insurance after a dispute over my borehole pump that was stolen? I would have had no problem with
Take your situation to your insurance commissioner. When you apply for new insurance, the new company is getting a bad report from the one that cancelled you. The insurance commissioner can force the issue and set things right for you.
Sep 30, 2014 | Computers & Internet
How much wattage is needed to run z57 zoeller pump
It probably draws about 6 amps so the power is 720 watts. Put it on a separate 15 Amp fused line so it doesn't put electrical noise into other items such a TV or radio for best results.
Apr 28, 2014 | Zoeller M53 Mighty Mate Iron Body, Poly...
Is it compulsory to buy health insurance from these new marketplaces after October 1?
Even if you don't have health insurance, it is not compulsory to purchase health insurance from new marketplaces. If you are uninsured, you might have to pay a fine after January 1, but for some people, that fine is going to be much lesser than what they might have to pay for health insurance plans.
Oct 15, 2013 | Cars & Trucks
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
www.wikihow.com/Calculate-Wattage
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
I have a1966 chevy impala,should I replace upper and lower ball joints at same time joints
I would if for no other reason insurance. you'll know for your self what you have and your already there with it all taken apart it's just cheap insurance in my book
Jul 15, 2012 | Cars & Trucks
I have a Miele CVA 615 coffee system and the pump does not work. Miele wants $800 for the replacement part alone, and I read on the internet that the part is actually a SAECO pump. Does anyone know which...
Hi Saeco uses 2 different pumps in their machines. The most common is the Ulka EX5, and the other is the Ulka EAX5 The only difference is the wattage. EX5 is 41w and the EAX5 is 52w. Need to know what wattage your pump is.
Jul 06, 2011 | Miele Coffee System
I recently purchased a denon av surround re- ceiver avr-2805,and a set of cerwin-vega LS-15, (separetly). When playing a cd though my dvd player, at around 0.0dB and up the fuses will blow in both speakers...
Depending on the wattage of the amp to the wattage off the speakers depends on what to use and how to control them..If your speakers are rated for more power than the amp can produce it will blow the fuses just as if the amp is rated for more than the speakers it will blow the fuse..Those type of speakers do need a good supply of power to run and speaker wire size could play an important part of that.If wire supply is to small it will over heat the coil in speakers and also blow the fuse...Look in side of the boxes to see what kind of capacitors they have on the speakers or there size to insure correct for speakers them selves..Also look at all of the wire routling in the amp to insure proper installation..Hope this helps you..Have a great day
Apr 03, 2009 | Cerwin Vega LS-15 Speaker
Dodge ram fuel pump, Caused by frontal Accident?
this of course could have bent the fuel pump bracket inside the tank or damaged the wiring that supplies it power, stand by your guns, if it worked before the accident then it is accident related, I have had this kind of argument with a few insurance companies, and they always say no until u really pour it on, ask to speak to a supervisor, forget the little claims agent go over his head, it works, just be persistant..
Feb 23, 2009 | 1998 Dodge Ram 1500 4WD
NEED POWER SUPPLY FOR ELITEGHROUP L7VMM2 MOTHERBOARD
There is no specific power suppl that you need. The only differce is the wattage 300, 350 , 500 etc. Your motherboard will work with all types not to worry. The only reason you get a higher wattage power supply is if you plug in a lot of stuff. say you have 3 HDD and 2 CDROMS then you would need the 500 Watt power supply.
Jan 05, 2009 | E-Machines (ATX-300GT) (ATX30012) 300-Watt...
Open Questions:
See all Whirlpool GU2400XTPS Built-in Dishwasher Questions
Whirlpool GU2400XTPS Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
