Question about Dell 924 All-in-One InkJet Printer
Unsupported cartridge - right cartride incorrect
All of a sudden, out of the blue getting this msg. Cleaned them but still getting the message. Was the "correct" cartridge yesterday. Help appreciated.
  • 1,031 Answers
The catridge changed does not meet the specification required,make sure you use the original catridge not adultrated one the printer will reject it
Posted on May 27, 2008
Receive msg: "Print Cartridge(s) missing or not detected
i thing u have problem with your cartride try to buy orgnal cartride and try if not then you have to go to work shop becoz u r cartride slot if not working properly
Apr 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Cartridge errors..cartridge incorrect
sounds like they're the type of cartridges that cannot be refilled, due to the computer chip on them.
Dec 31, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 750xi - Incorrect color printer cartridge installed error
I had this same problem and by a luck I fixed it. Not sure if the method to the madness had anything to do with it, but I'll put it down in the order that I did everything. 1. reset to factory defaults 2. pulled all cartridges out. it prompted me to put color in first, then black. message was still blinking so i took out color and put it back in again. 3. i did the partial reset by holding down cancel and left arrow while i unplugged/replugged the printer. 4. no the printer started displaying "remove and check color cartridge" (or something to that degree) 5. i took out color cartridge, cleaned the contacts with water on towel, and replaced cartridge. 6. same message still being displayed, but it allowed me to print a maintenance report. so i then cleaned cartridges and aligned cartridges through standard menu. 7. msg still being displayed, so i turned off/on printer again. this time it came back up with no message at all. 8. printer now works
hope this helps and works for ya'll too!
Sep 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Incorrect right cartridge - unsupported cartridge.
I had the same "unsupported ink cartridge" thing going on with hp until I got fed up and uninstalled the hp software and just used my windows devices and printers. Windows will automatically find drivers for your printer and you should be able to choose how much of that software you want to download and install. Eventually I did get some software from hp but I still use Windows fax and scan. When I had a chance to participate in a questionnaire, I made it plain to hp that it's my printer, my ink, my cartridges and I'll do what I want with them. I'll take them out and use them for a planter if I want! In the meantime, I do expect them to print with whatever I put in them. It might not be as good a quality as the original, but it's still my right.
May 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell All-in-one 924 error: "right cartridge is incorrect"
Hi ,
if you are getting the error msg 12203 , pperform the following steps,
remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
remove the black cartridge and put the color one in, and then try printing.
during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
Mar 05, 2008 | Dell 924 All-in-One InkJet Printer
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
HP LJ 2840 problem
I'm about to dive into the printer and change the carousel. I'm having the same incorect yellow msg even when the cartridge is not inserted... I'll be back with further info.
Feb 12, 2008 | HP LaserJet 2840 All-In-One Printer
Right cartridge incorrect
Try cleaning the contacts on both the cartride and in the cartridge bay
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Solve this
I could be mistaken but I am pretty sure the right cartridge should be the black one. I would double check it. Also make sure you are using Dell brand cartridges.
Aug 03, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
189 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
