Question about Canon PIXMA MP210 Photo All-In-One Printer
I have error 5 and when i pu my old inkt patrons in the machine than i bocome 1 and error 6 what is the problem? can you give me advice?
    Sergeant:
    Champion:
  • 293 Answers
Reset your Canon PIXMA MP210 Photo All-In-One Printer
Posted on Oct 04, 2010
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
E.pu error in keb f5 inverter. the part no. is 09.f5.a1d-3a4a, ver. 1.0, 1.5kw. when powering up the drive, it gives 560VDC. please recommend what the problem could be.
The E.pu error is a general power stage failure.
Typically means that the unit has a defective power stage that would need to be replaced.
If it is an old inverter(early 2000's) there is a possibility that it could be a cooling fan problem since at that time there was a three wire fan used. May be able to replace the fan (must obtain from KEB) but there may still be problems with power stage. If it is from early 2000's then you might be better off replacing the unit with new current version.
Mar 10, 2014 | Inverter KEB COMBIVERT F5
Originaldruckerpatrone wird nicht erkannt
Sicherstellen, dass die Lexmark Patrone ist nicht leer.
Versuchen Sie, die Patrone in den Drucker neu ein. Bitte folgen Sie den Schritten unten:
1. Entfernen Sie die Patrone aus dem Drucker.
2. Schließen Sie die Druckerabdeckung.
3. Ziehen / re-Stecker des Druckers in die Steckdose, um es zurückzusetzen.
4. Wenn der Drucker eingeschaltet wird, setzen Sie die Patrone.
5. Wenn der Fehler erscheint, versuchen, einen anderen bekannten Arbeiten zu bestimmen, ob es sich um eine fehlerhaftePatrone Problem ist einzufügen.
Wenn Ihr Original Lexmark Patrone gefunden fehlerhaft (nicht leer), kontaktieren Sie bitte Lexmark Technical Support Centerfür weitere Unterstützung.
Hinweis: Dies ist übersetzt mit translate.google.com.
Aug 24, 2011 | Lexmark P350 InkJet Photo Printer
Hi there, i have an hp 3500 printer. the fuser was ript appart and needed replacment.(the rol was broken on one side and was not burning the inkt on the paper anymore) i have got a new one, but keep...
50.9 error - Fuser Failure (Abnormally High
Temperature Sub Thermistor)
1. The connector between the fuser and
the printer is not connected properly.
Reseat the fuser. Check the connector J5013
between the fuser and the printer. Replace it
if damaged.
2. Short in the sub thermistor. Turn the
printer off and remove the fuser. Measure the
resistance between the fuser connectors
J5013LA-4 (SUBTH) and J5013LA-3
(+3.3V). If it reads 600 ohms or below (at
ambient temperature), replace the fuser.
3. Faulty DC controller PCB, replace the
DC controller PCB.
I think you've some problems on the connectors, check the connections.
If you are able, replace the broken fuser roller from the old fuser with one from the new fuser.
Jun 09, 2011 | HP Color LaserJet 3500 Printer
Ich habe mit meinem HP Photosmart C6380 das Problem, Fehler im Tintensystem Oxc 19a 0023, bzw 0036
Vergewissern Sie sich, dass die Patronen sind installiert richtig 1. Drehung auf dem Produkt 2. die Patrone Zugriffstür Aufhebt, es zu öffnen. 3., Die Patrone zu entfernen, drückt die Lasche auf der Vorderseite der Patrone, es freizugeben, und
entfernen Sie dann es vom Steckplatz.
4. untersucht das Belüftungsschlitzgebiet, das auf die Patrone befunden ist, neben dem HP Firmenzeichen 5., Wenn eine orange Lasche zu irgendeiner Patrone befestigt ist, entfernt es. 6., wenn welcher der Patronen Belüftungsschlitze verstopft hat, benutzt eine Nadel, die Belüftungsschlitze zu reinigen. 7. benutzend das hat gefärbt Gestaltabbilder für Hilfe, schiebt jede Patrone in den richtigen leeren Steckplatz, und drücken Sie dann hinunter, bis die Patrone streng in Ort im Steckplatz schnappt. 8. schließt die Patrone Zugriffstür. 9. prüft die Produktschalttafel Ausstellung.
Anweisungen sind auf dieser Verbindung:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=en&cc=us&product=3560280#N65
Klicken Sie diese Verbindung an oder Kopie und fügen Sie die vollständige Verbindung in Ihren Browser ein. Wenn ich von weiterer Hilfe sein könnte, lassen Sie mich wissen. Wenn dies hilft, oder löst die Ausgabe, schätzt bitte es ein und gibt eine Referenz für meinen Erwiderungsdank,
Joe
Jan 30, 2011 | HP Photosmart C6380 All-In-One InkJet...
Okidata C7300 Fatal Error 120
Service call 120: error
PU unit fan motor
1. Is fan in PU operating?
NO - Replace Fan motor.
YES - Replace engine control board (K7N).
2. Error reoccurs after replacing fan motor.
Jan 18, 2011 | OKI C7300 Led Printer
My wood floors in my living and dining rooms have 4 coats of polyurethane. This was done professionally about 5 yrs. ago. I want to give the floors a facelift by adding another coat of polyurethane. What...
This will dependa litlle on the type of Polyurathane that was originaly put down - single pack or two pack and if you have done any type of upkeep to it in the mean time. Some people like to wax there floors to give them shine and a deadly slip factor, if you have waxed your floor you need to remove this wax before youo go any further. Talk to a local chemical supplier to find a wax remover. If you have not waxed your floor this makes it easy.
Wash the floor with a solvent cleaner that contains no waxs or soaps - I use mineral Turpentine on clean rags.
Sand the floor with a hand sander (orbital, vibrating or belt your choice, I prefer to use a square vibrating sander or 8" Orbital) - you do not need a floor sander unless you want to remove all your PU and get back to bear timber. The process of sanding is designed to rough up the whole top surface so that a new layer of PU will adhear to the old PU. So use about a 80 gritt pad. to fine a sand paper will not give a good key for the new PU and to rouogh a paper may scratch to deep into your floor.
Note: if your original floor was stained you must be very carful not to sand all the way through the PU as the timber underneath will show through as a differant colour.
Dust off the floor with a clean broom to remove the bulk of the dust then use Methalated spirits on clean rags and completly clean the floor. You are now ready to start applying the PU as per the manufacturers specifications.
Other things to note:
1) I always wear socks when cleaning back the floor for the last time as oil from your feet and hands can transfere onto the floor and cause small patches were the PU does not adhere properly.
2) After the reccomended drying time I always insist that my clients wait an additonal 24 - 48 hours to allow the PU to fully harden before they walk on it or move furniture. A lot of the PU manufactures seem to cut down there drying times to make there product more appealing to busy market.
Hope this helps.
Jun 24, 2009 | Tools & Hardware - Others
Signal waste inkt is full
Hello hope this will do the trick for you
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 15, 2008 | Canon SmartBase MP730 All-In-One InkJet...
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
Feb 19, 2008 | OKI C5550N Multifunction Printer - Color...
Canon MP180 Ink Problem
lads ye're all I work in an 'ink place' and the u051 fault is a fault indicating that the offending cartridge is electrically dead, this is caused by the clever little program in the canon machine that writes info to the cartridge to make it'dead' so it cant be re-used ! possible solution is to get refilled before printer thinks it empty !!
Feb 09, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
367 people viewed this question
old marine
old marine
