Question about T-Mobile Dash Smartphone
Activesync trouble when I try Activesync on my dash, I get this error message "Syncronation cannot be completed successfully. Reconnect your device and try again. If the problem persists, see the Microsoft Activesync Troubleshooter in Microsoft Activesync help on your desktop computer". Only thing mentioned there are about firewalls, but I'm using the same computer that I've always used
    Problem Solver:
  • 18 Answers
Have you tried a differnet cable? I saw somthing similar due to a bad cable - even worse a bad connection on the phone.
- check your device settings on PC.
- remove the device by deleting it in device manager and then re-install.
to go to device manager:
- right click on MY COMPUTER ICON
- Scroll down to manage
- find devicre manager
- look for device under usb
-right click delete.
Posted on May 28, 2008
Updating my tmobile dash
To update your T-Mobile Dash Smartphone, please follow this steps,
1. Download the new software to your PC. You will be instructed to enter the 15-digit IMEI number for your device to access the download.
2. Ensure ActiveSync 4.5 for computers using Windows XP or earlier or use Windows Mobile Device Center for computers using Vista and Windows 7 is installed on your PC. If you have not installed ActiveSync or Windows Mobile Device Center, you can install it from your Getting Started CD or download it from the Microsoft website.
3. Connect your Dash to your computer using the USB Sync Cable that came with the phone.
4. Establish a connection. You will know this is complete when the ActiveSync or Windows Mobile Device Center icon in your PC taskbar is lit green and the status is "Connected".
5. Ensure that your T-Mobile Dash has a battery charge that is greater than 50% (two bars).
6. Remove your MicroSD card from the device if you have one inserted. Do not reinsert the SD card until after the software installation process is complete and the phone is ready to use.
7. Run the software update program you downloaded to your PC and follow the on-screen commands.
To get the software update , follow this instruction : CLICK ME
To get user guide manual : DOWNLOAD
Thank you for visiting FixYa...
Aug 24, 2011 | T-Mobile Dash Smartphone
HP Pocket 2003. Need to restore information but not recognising profile. Where do I find the files on PC to copy mobile devise. Using XP student edition
Syncronation profile? you should make a new active sync profile.
or do you mean something else? please be more spesific.
if your device was hard reset and you need to restore something.
tell me what exactly.
Mar 28, 2008 | Computers & Internet
Canon pixma mp 250 won't print. Comes up with error 5100
Hi there.. i understand that you're having troubles printing from your computer because of that error message.. dont worry im here to help you out with that..
Here's what you can do:
  1. At the device or at the electrical outlet, disconnect the power cord or adapter (while the printer is turned on).
  2. Wait approximately ten to twenty seconds and then reconnect the power cord.
  3. Wait until the device has completed its cycling process before submitting another job request.
normally the reason why it is saying that error message its because the printer is not responding so that's why we will need to power reset you printer..
If you have any other questions, dont hesitate to reply on this message.. thanks and Good Luck!
Jun 01, 2011 | Canon Office Equipment & Supplies
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
I AM TRYING TO SYNC MY HP iPAQ TO MY COMPUTER, BUT AN MESSAGE ERROR SAYS THAT 'RAPI.DLL' IS MISSING. WHERE I CAN DOWNLOAD 'ACTIVE SYNC' AND 'RAPI.DLL'
You can download the Microsoft ActiveSync from:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
This package contains the rapi.dll inside it.
Note: Microsoft ActiveSync is for windows XP and earlier version only. In case of Microsoft VISTA download Windows Mobile Device Center.
Jul 11, 2009 | HP iPAQ RX3115 Pocket PC
Microsoft ActiveSync Connection Manager Crashes Windows
Uninstall Active Synch then Turning off your PC unplug the power cable from the power socket, then short the leds on the PC power cable and leave it for 5min. then reconnect the Power cable to power socket and turn on the PC install activesynch and it should work.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
ActiveSync Trouble
Hi I had the same error/problem. What version of Active Synch are you using. You may meed to go to Microsoft Mobile site and download the latest verison of Active Synch. This should fix the problem. If you need further help, email me and we can do a go to meeting and i will help you troubleshoot the problem further. I use my PDA for everythin, and I know how frustrating it can be. Here is my email hartmansp@inbox.com Have a gret day.
May 09, 2007 | ViewSonic V36 Pocket PC
ActiveSync
try soft reset on your Ipaq and a restart of your PC.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
EM-500 Conection Problem
Upgrade Activesync and the PC's USB driver. Then you should be OK once you upgrade Activesync to V3.6 and then get the latest USB driver for your system. Good luck
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
T-Mobile Dash Smartphone Logo
56 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
